Dear Support,
I would like to create a check with a long-running external script(~5 minutes) from nagios.
I copied check_nrpe command and increase timeout on it.
I've changed command_timeout=600 in NSC.INI in the plugin.
Still getting the following error:
Could you please help me? What elso do i have to change?
Thanks in advance!
Regards,
Zoltan
NRPE timeout
patalenszki.zoltan
NRPE timeout
avandemore
Re: NRPE timeout
In /usr/local/nagios/etc/nagios.cfg there are global timeout settings. service_check_timeout=60 is one of these. You would have to change that to some value equal or greater than the service timeout and the restart nagios.
Previous Nagios employee
patalenszki.zoltan
Re: NRPE timeout
Thank you! It works.
Re: NRPE timeout
Are we good to mark this thread as resolved and close it out?
