Hi NagiosXI guys,
Your installation script is buggy. https://assets.nagios.com/downloads/nag ... ctions.pdf
I got errors from your Nagios installation shell script when attempted to install on RHEL 7.3. After troubleshooting, I found and fixed the issue.
1. False handling controls of selinux.
- Manually disable selinux and uncomment the line "systemctl disable selinux" in D-chkconfigalldaemons
2. We no longer use SystemV
- Replace killall by killall5 in E-importnagiosql
I hope this can help some people.
NagiosXI manual installation errors.
- Former Nagios Staff
Re: NagiosXI manual installation errors.
Thanks for the feedback! For clarity, you were installing 5.3.2? That's what wget http://assets.nagios.com/downloads/nagi ... est.tar.gz should get you, but I just want to be sure. We didn't have any problems installing with CentOS 7.2, but I don't believe we've tested on 7.3. We'll have to look into it.
Thanks again!
Thanks again!
