Hi Team,
I have configured bandwidth monitoring for Network devices in NagiosXI and under reports section we are able to fetch the Bandwidth usage report but I don’t see
option to customize the report based on time interval so could you please suggest on this.
EG : How to generate report to pull the bandwidth usage for last 3 or 6 months .
Bandwidth Report generation using Custom TimeInterval
rs00469183
avandemore
Re: Bandwidth Report generation using Custom TimeInterval
You can select a performance graph period as shown:
Other addons like PNP4Nagios may have other graphing options, but those are 3rd party.
Previous Nagios employee
