Snmp traps are coming as unknown
ericssonvietnam
Post by ericssonvietnam »
hi Support,
Even if i define EVENTS in snmptt.conf, still traps are comming as "unknown". Could you please help me troubleshooting it.
I am running, nagiosXI 5.2.9 on centos 6. My configuration goes as follows:-
 In snmptt.ini
  snmptt_conf_files = <<END
/etc/snmp/userdefined_snmptt.conf
/etc/snmp/snmptt.conf
END
[root@strmon snmp]# cat /etc/snmp/userdefined_snmptt.conf
EVENT TapeSuspended SNMPv2-SMI-v1::enterprises.11.2.36.1.0.4  "Status Events" Normal
FORMAT $*
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "$*"
EVENT TapeSuspended SNMPv2-SMI-v1::enterprises.11.2.36.1.0.5  "Status Events" Normal
FORMAT $*
EVENT TapeSuspended SNMPv2-SMI-v1::enterprises.789.0.134  "Status Events" Normal
FORMAT $*
EXEC /usr/local/bin/sinmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "$*"
EVENT TapeSuspended SNMPv2-SMI-v1::enterprises.789.0.532  "Status Events" Normal
FORMAT $*
EVENT TapeSuspended SNMPv2-SMI-v1::enterprises.789.0.666  "Status Events" Normal
FORMAT $*
EVENT TapeSuspended SNMPv2-SMI-v1::enterprises.789.0.85  "Status Events" Normal
FORMAT $*
FORMAT $*
EVENT TapeSuspended SNMPv2-SMI-v1::enterprises.789.0.87  "Status Events" Normal
FORMAT $*
Still after service restart, traps are coming in /var/log/snmptt/snmpttunknown.log as "unknown":-
Mon Nov 21 16:46:47 2016: Unknown trap (SNMPv2-SMI-v1::enterprises.11.2.36.1.0.4) received from HOSTS at:
Value 0: HOSTS
Value 1: X.X.X.X
Value 2: 0:0:00:00.00
Value 3: SNMPv2-SMI-v1::enterprises.11.2.36.1.0.4
Value 4: X.X.X.X
Value 5:
Value 6:
Value 7:
Value 8:
Value 9:
Value 10:
Ent Value 0: SNMPv2-SMI-v1::enterprises.11.2.36.1.1.5.1.1.1.1=1
Ent Value 1: SNMPv2-SMI-v1::enterprises.11.2.36.1.1.5.1.1.4.1=1.3.6.1.4.1.11.10.2.1.3.25
Ent Value 2: SNMPv2-SMI-v1::enterprises.11.2.36.1.1.5.1.1.2.1=HPMSl
Ent Value 3: SNMPv2-SMI-v1::enterprises.11.2.36.1.1.5.1.1.5.1=http://X.X.X.X
Ent Value 4: SNMPv2-SMI-v1::enterprises.11.2.36.1.1.5.1.1.6.1=Command View MSL
Ent Value 5: SNMPv2-SMI-v1::enterprises.11.2.36.1.0.10=0x0001=Move event ;Event Code: =0x01 - move medium ;Task originator: =0x02 - CDB interpreter task ;Source element type.: =0x04 - tape drive ;Element number: =0x02, 2;Destination element type.: =0x02 - storage slot ;Element number: =0x3D, 61
Ent Value 6: SNMPv2-SMI-v1::enterprises.11.2.36.1.0.11=Unknown
Ent Value 7: SNMP-COMMUNITY-MIB::snmpTrapAddress.0=X.X.X.X
Ent Value 8: SNMP-COMMUNITY-MIB::snmpTrapCommunity.0=ubsmonitoring
Ent Value 9: SNMPv2-MIB::snmpTrapEnterprise.0=SNMPv2-SMI-v1::enterprises.11.2.36.1
[root@strmon snmp]# grep -w SNMPv2-SMI-v1::enterprises.11.2.36.1.0.4 ./*
./userdefined_snmptt.conf:EVENT TapeSuspended SNMPv2-SMI-v1::enterprises.11.2.36.1.0.4  "Status Events" Normal
Please suggest steps to fix it..
Re: Snmp traps are coming as unknown
The formatting of the entries in your /etc/snmp/userdefined_snmptt.conf file look like they are incomplete and there are some spelling errors as well.
A typical entry should look like the example below.
EVENT hpHttpMgOKHealthTrap .1.3.6.1.4.1.11.2.36.1.0.4 "Status Events" Normal
FORMAT The device's health has changed to OK. $*
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "The device's health has changed to OK. $*"
SDESC
Variables:
  1: hpHttpMgDeviceIndex
  2: hpHttpMgDeviceSysObjID
  3: hpHttpMgDeviceGlobalUniqueID
  4: hpHttpMgDeviceManagementURL
  5: hpHttpMgDeviceManagementURLLabel
  6: hpHttpMgDeviceSpecificEventCode
  7: hpHttpMgDeviceSpecificFRU
EDESC
The fastest way to fix this is to delete the bad entries and re-add them by running this command. You will need to specify the path and the name of the MIB file in the command.
addmib /path/MIBfile
This will add the update the entries in the /etc/snmp/snmptt.conf file and you will need to restart the snmptt daemon for the changes to be applied.
service snmptt restart
Try that and let us know if you have any other questions.
ssax
Dreams In Code
Post by ssax »
What type of device is this?
Please send me the output of this command (run it on the XI server):
grep -R 'SNMPv2-SMI-v1' /usr/share/snmp/mibs/*
Did you install the SNMPv2-SMI-v1 MIB?
wget ftp://ftp.cisco.com/pub/mibs/v1/SNMPv2-SMI-V1SMI.my -O /usr/share/snmp/mibs/SNMPv2-SMI-V1SMI.my
If you restart SNMPTT does it output any messages?
ericssonvietnam
Sorry for delayed responce..i was on leave last week. Below are the requested data:-
"The formatting of the entries in your /etc/snmp/userdefined_snmptt.conf file look like they are incomplete and there are some spelling errors as well."
Entries are manually done for "OID's" apperiand as "UNKNOWN". I've replaced "SNMPv2-SMI-v1::enterprises" with ".1.3.6.4.1' in file. Will check and update if this changes make any difference.
"What type of device is this?"
I am trying to monitor storage hardware, like, tape, netapp, san switch..etc"
"output of this command grep -R 'SNMPv2-SMI-v1' /usr/share/snmp/mibs/*"
/usr/share/snmp/mibs/host-resources-mib.mib: FROM SNMPv2-SMI-v1
/usr/share/snmp/mibs/radlan-mib.mib: FROM SNMPv2-SMI-v1
/usr/share/snmp/mibs/SNMPv2-SMI-v1.mib:SNMPv2-SMI-v1 DEFINITIONS ::= BEGIN
/usr/share/snmp/mibs/snmpv2-tc-v1.mib:-- SNMPv2-SMI-v1 DEFINITIONS ::= BEGIN
/usr/share/snmp/mibs/snmpv2-tc-v1.mib:-- FROM SNMPv2-SMI-v1;
"service snmptt restart" : do not report any error.
ericssonvietnam
Also,
@tgrip:- .1.3.6.1.4.1.11.2.36.1.0.4 is exactly defined as you said in snmpt.conf.
SDESC
Variables:
EDESC
I've noticed above duplicate entry hence removed "userdefined_snmptt.conf" and restarted snmptt service. But still getting below entry in unknown logs.
Tue Dec 6 12:04:26 2016: Unknown trap (SNMPv2-SMI-v1::enterprises.11.2.36.1.0.4) received fromX>X>X>X>X at:
Value 0: X>X>X>X>X>X>
Value 1: X>X>X>X>X>
Value 4: 150.236.201.202
Value 5:
Value 6:
Value 7:
Value 8:
Value 9:
Value 10:
Ent Value 2: SNMPv2-SMI-v1::enterprises.11.2.36.1.1.5.1.1.2.1=X.X>X>X>X>X>
Ent Value 3: SNMPv2-SMI-v1::enterprises.11.2.36.1.1.5.1.1.5.1=http://X.>X>X>X>X>
Ent Value 5: SNMPv2-SMI-v1::enterprises.11.2.36.1.0.10=0x0042=Login event ;Event Code: =0x0A - login ;Task originator: =0x0F - Remote management interface ;Permission level: =0x02 - administrator
Ent Value 7: SNMP-COMMUNITY-MIB::snmpTrapAddress.0=X>X>X>X>X
Ent Value 8: SNMP-COMMUNITY-MIB::snmpTrapCommunity.0=X>X>X>X>X>
Uploading snmptt.ini(
snmptt.ini
) and snmpt.conf(
snmptt.conf
ssax
Dreams In Code
Post by ssax »
I imported your /etc/snmp/snmptt.conf and /etc/snmp/snmptt.ini, restarted snmptt, and submitted the command manually and it worked for me so it's not likely a SNMPTT configuration issue.
Does it show in the unknown log if you manually submit it from the XI server's command line?
snmptrap -v2c -cpublic 127.0.0.1 1431439518 SNMPv2-SMI-v1::enterprises.11.2.36.1.0.4 .1.3.6.1.2.1.2.2.1.1.1 i 1 .1.3.6.1.2.1.2.2.1.7.1 i 2 .1.3.6.1.2.1.2.2.1.8.1 i 2 .1.3.6.1.2.1.2.2.1.2.1 s Vlan1 .1.3.6.1.2.1.2.2.1.3.1 i 53 .1.3.6.1.4.1.9.2.2.1.1.20.1 s "administratively down" .1.3.6.1.6.3.18.1.3.0 a 172.29.2.254 .1.3.6.1.6.3.18.1.4.0 s LIV-NET .1.3.6.1.6.3.1.1.4.3.0 o .1.3.6.1.6.3.1.1.5
Please run this command and send us the resulting /tmp/SUPPORTFILES.zip file:
zip -r /tmp/SUPPORTFILES.zip /etc/snmp /usr/share/snmp/mibs
Also, post the output of these commands:
ls -lh /usr/sbin/snmptthandler
ls -lh /usr/local/bin
Thank you
ericssonvietnam
Requested O/P:
[root@strmon mibs]# ls -lh /usr/sbin/snmptthandler
-rwxr-xr-x 1 root root 6.4K Oct 22 2012 /usr/sbin/snmptthandler
[root@strmon mibs]# ls -lh /usr/local/bin/
total 23M
-rwxr-xr-x 1 root nagios 804 Jun 29 16:48 addmib
-rwxr-xr-x 1 root root 2.4K Jun 29 16:48 snmptraphandling.py
-rwxr-xr-x 1 root root 30K Jun 29 16:48 snmpttconvertmib
-rwxr-xr-x. 1 root root 9.0M Dec 2 2011 winexe
-rwxr-xr-x. 1 root root 14M Dec 2 2011 wmic
[root@strmon mibs]#
it looks like there are couple of MIB's loaded generating error while snmptt restart. Definitely i need to clean them up. As they are more in numb, could please suggest best way to preform cleanup of non-functional MIB's?.
Below are the error reported by snmptt while restart..
Undefined identifier: hpSwitchBladeType5-Mgmt near line 23827 of /usr/share/snmp/mibs/gbe2c-1-10g-l2l3.mib
Unlinked OID in BLADETYPE5-NETWORK-MIB: acl ::= { hpSwitchBladeType5-Mgmt 9 }
Undefined identifier: hpSwitchBladeType5-Mgmt near line 22169 of /usr/share/snmp/mibs/gbe2c-1-10g-l2l3.mib
Unlinked OID in BLADETYPE5-NETWORK-MIB: bntTraps ::= { hpSwitchBladeType5-Mgmt 7 }
Undefined identifier: hpSwitchBladeType5-Mgmt near line 21911 of /usr/share/snmp/mibs/gbe2c-1-10g-l2l3.mib
Unlinked OID in BLADETYPE5-NETWORK-MIB: layer3 ::= { hpSwitchBladeType5-Mgmt 3 }
Undefined identifier: hpSwitchBladeType5-Mgmt near line 11056 of /usr/share/snmp/mibs/gbe2c-1-10g-l2l3.mib
Unlinked OID in BLADETYPE5-NETWORK-MIB: layer2 ::= { hpSwitchBladeType5-Mgmt 2 }
Undefined identifier: hpSwitchBladeType5-Mgmt near line 5873 of /usr/share/snmp/mibs/gbe2c-1-10g-l2l3.mib
Unlinked OID in BLADETYPE5-NETWORK-MIB: agent ::= { hpSwitchBladeType5-Mgmt 1 }
Undefined identifier: hpSwitchBladeType5-Mgmt near line 53 of /usr/share/snmp/mibs/gbe2c-1-10g-l2l3.mib
Unlinked OID in BLADETYPE5-NETWORK-MIB: hpProLiant-GbE2c-1-10G-InterconnectSwitch ::= { hpSwitchBladeType5-Products 1 }
Undefined identifier: hpSwitchBladeType5-Products near line 44 of /usr/share/snmp/mibs/gbe2c-1-10g-l2l3.mib
Did not find 'compaq' in module CPQHOST-MIB (/usr/share/snmp/mibs/cpqdsccs.mib)
Did not find 'sysName' in module RFC1213-MIB (/usr/share/snmp/mibs/cpqdsccs.mib)
Did not find 'sysDescr' in module RFC1213-MIB (/usr/share/snmp/mibs/cpqdsccs.mib)
Did not find 'sysContact' in module RFC1213-MIB (/usr/share/snmp/mibs/cpqdsccs.mib)
Did not find 'sysLocation' in module RFC1213-MIB (/usr/share/snmp/mibs/cpqdsccs.mib)
Unlinked OID in CPQDSCCS-MIB: cpqDsccs ::= { compaq 171 }
Undefined identifier: compaq near line 212 of /usr/share/snmp/mibs/cpqdsccs.mib
Expected "(" (_): At line 282 in /usr/share/snmp/mibs/nsainfo.mib
Should be ACCESS (Vectra): At line 282 in /usr/share/snmp/mibs/nsainfo.mib
Bad parse of OBJECT-TYPE: At line 282 in /usr/share/snmp/mibs/nsainfo.mib
Did not find 'enterprises' in module RFC1155-SMI (/usr/share/snmp/mibs/smsagent.mib)
Unlinked OID in SMSAGENT-MIB: unisys ::= { enterprises 223 }
Undefined identifier: enterprises near line 11 of /usr/share/snmp/mibs/smsagent.mib
Did not find 'enterprises' in module RFC1155-SMI (/usr/share/snmp/mibs/adaptec.mib)
Unlinked OID in CYCLONE-MIB: adaptec ::= { enterprises 795 }
Undefined identifier: enterprises near line 22 of /usr/share/snmp/mibs/adaptec.mib
Did not find 'compaq' in module CPQHOST-MIB (/usr/share/snmp/mibs/cpqlinos.mib)
Did not find 'sysName' in module RFC1213-MIB (/usr/share/snmp/mibs/cpqlinos.mib)
Unlinked OID in CPQLINOS-MIB: cpqLinOsMgmt ::= { compaq 23 }
Undefined identifier: compaq near line 42 of /usr/share/snmp/mibs/cpqlinos.mib
Did not find 'hh3c' in module HH3C-OID-MIB (/usr/share/snmp/mibs/hh3c-common-system-mib.mib)
Unlinked OID in HH3C-COMMON-SYSTEM-MIB: hh3cSystem ::= { hh3c 6 }
Undefined identifier: hh3c near line 34 of /usr/share/snmp/mibs/hh3c-common-system-mib.mib
Did not find 'hrMIBAdminInfo' in module HOST-RESOURCES-MIB (/usr/share/snmp/mibs/HOST-RESOURCES-TYPES.txt)
Did not find 'hrStorage' in module HOST-RESOURCES-MIB (/usr/share/snmp/mibs/HOST-RESOURCES-TYPES.txt)
Did not find 'hrDevice' in module HOST-RESOURCES-MIB (/usr/share/snmp/mi
ericssonvietnam
i've preformed cleanup for all newly added MIB'S and tryied to execute your snmptrap test command.But nothing get logged snmpttunknown.log.Also it says module is missing but i can see it is there is same path.
/usr/share/snmp/mibs/SNMPv2-SMI.txt
No log handling enabled - turning on stderr logging
Cannot find module (SNMPv2-SMI-v1): At line 0 in (none)
SNMPv2-SMI-v1::enterprises.11.2.36.1.0.4: Unknown Object Identifier
ericssonvietnam
Looks like there was couple of issue:
1: Most of the MIB's loaded were reporting error at time of service snmptt restart : removed each of them
2: Node where integrated to XI with hostname only where as trap where coming from FQDN, Hence the mismatch: Fixed it by "strip_domain =1" in snmptt.ini
Now Traps are appearing as expected on XI portal.
Now only Q unanswered is why i am getting module missing even when file exists in path ( Q from last post i.e Cannot find module (SNMPv2-SMI-v1): At line 0 in (none)).
You still appear to be missing the MIB file, what are the permissions on it? I suspect it's either permissions, or not done properly. Take a look at this link for a further explanation - http://www.net-snmp.org/FAQ.html#What_d ... IB___mean_
