Monitoring by SNMP
Cristhian_Plaza
Monitoring by SNMP
Hi, I have a question, I have two Nagios Core servers, I want to monitoring a Ubuntu and RHEL 7 server by snmp. I'll give an example for my problem because I don't understand what is happening.
With the first Nagios Core server, I am monitoring the ram memory used and free disk by snmp on a Ubuntu server without problem.
With the second Nagios Core server, I am monitoring the ram memory used by SNMP on a RHEL 7 server without problems, but free disk is going wrong I don't know why, why can I monitoring the memory RAM used by SNMP and cannot monitoring free disk by SNMP?.
Of course I installed net-snmp-utils, net-snmp, net-snmp-libs and configured the snmpd.conf on RHEL7, so I don't understand what is the problem.
The answer of Nagios is, External command error: Error in packet.
Re: Monitoring by SNMP
Can you post the two service definitions, and related command definitions from each machine? Please identify which is which, so we can see the difference you're achieving on your disk result.
Cristhian_Plaza
Yes, the services are defined in the same way.
My two Nagios servers are on CentOS
First server.
Command and Services on Ubuntu 14.04
In that services there isn't problem, it works fine.
Second service
Commands and services on RHEL 7
Here is the problem, memory RAM (Ram_tamaño) is working fine, but free disk (Disco_disponible) is not workgin fine, the error is:
External command error: Error in packet, so I don't understand.
First server.
command_name snmp_RamSize
command_line $USER1$/check_snmp -o .1.3.6.1.4.1.2021.4.5.0 -H $HOSTADDRESS$ $ARG1$
command_name snmp_DiskAvailable
command_line $USER1$/check_snmp -o .1.3.6.1.4.1.2021.9.1.7.1 -H $HOSTADDRESS$ $ARG1$
host_name LinuxPruebas
service_description Tamaño de RAM
check_command snmp_RamSize!-C public
service_description Espacio Libre
check_command snmp_DiskAvailable!-C public
Second service
command_name Ram_tamaño
command_name Disco_disponible
host_name GLPI
service_description Ram asignado
check_command Ram_tamaño!-C public!
host_name GLPI
service_description Disco disponible
check_command Disco_disponible!-C public!
Cristhian_Plaza
I answered, please look for my topic.rkennedy wrote:Can you post the two service definitions, and related command definitions from each machine? Please identify which is which, so we can see the difference you're achieving on your disk result.
avandemore
Please run the full command on the command line. List the entire output. Example:
# /usr/local/nagios/libexec/check_snmp -o .1.3.6.1.4.1.2021.9.1.7.1 -H localhost -C public
Reason: (noSuchName) There is no such variable name in this MIB.
Failed object: iso.3.6.1.4.1.2021.9.1.7.1Previous Nagios employee
Cristhian_Plaza
I'm getting crazy...,avandemore wrote:Please run the full command on the command line. List the entire output. Example:Code: Select all
# /usr/local/nagios/libexec/check_snmp -o .1.3.6.1.4.1.2021.9.1.7.1 -H localhost -C public External command error: Error in packet Reason: (noSuchName) There is no such variable name in this MIB. Failed object: iso.3.6.1.4.1.2021.9.1.7.1
I have one Nagios server for test another Linux Server and another Nagios Server for the Job.
The Nagios Server for testing is working fine when monitoring a Ubuntu Server 14.04
The Nagios Server for Job is not working fine.
The Services that I'm monitoring in the two Nagios Servers are the same.
the response that you required is:
Reason: (noSuchName) there is no such variable name in this MIB
- Former Nagios Staff
try $USER1$/check_snmp -o 1.3.6.1.4.1.2021.9.1.7.1.0 -H $HOSTADDRESS$ $ARG1$
OIDs typically end with .0, the .0 indicates that it's a value. Notice that the RAM check ends in a .0.
Cristhian_Plaza
I tried, but got the same response, I don't know if is problem of Nagios, or problem from the another server. Why I can monitoring that OID from a Ubuntu server but cannot do it from a CentOS server. If you want see the difference I can give you the url from two servers.dwhitfield wrote:try $USER1$/check_snmp -o 1.3.6.1.4.1.2021.9.1.7.1.0 -H $HOSTADDRESS$ $ARG1$
Sure, if you want to PM them out of security concerns, that works. If no security concerns, you'll get quicker feedback if you post them in the thread.
If you do PM, please update this thread that you have done so. You updating this thread means it will pop back up on our dashboard.
avandemore
If that is your response, then the SNMP daemon on the system doesn't support that OID.Cristhian_Plaza wrote:Code: Select all
External command error: Error in packet Reason: (noSuchName) there is no such variable name in this MIB Failed object: iso.3.6.1.4.1.2021.9.1.7.1
