check_multi support
check_multi support
Is there by any chance some documentation about implementing check_multi in a (distributed) nagiosxi installation?
I ask because this check does several other checks displayed as 1. The problem however is that the performance data does not seem to be able to create graphs for this in the nagiosxi central we use.
Re: check_multi support
Not that we've written, here's what I found.
http://my-plugin.de/wiki/projects/check_multi/start
I had that one aswell and i got it fully working. The problem however is that the performance data isn't being used in the central.
Is performance data being returned to the server at all? Below is an outline as to what is needed for performance data to work correctly.
http://docs.pnp4nagios.org/pnp-0.4/abou ... quirements
The data is being returned to the server but i have the feeling the broken performance graphs have to do with the data not being processed. As soon as i get the new central up and running i will retry this.
Yeah, let us know what you find out. If there aren't any rrd files then you're not getting valid performance data. If you have rrd's but no graphs, then it's most likely a permissions issue.
http://support.nagios.com/wiki/index.ph ... h_Problems
I have configured the multi_check again with the new central and it seem it wants to create performance graphs but it cant because the data is being cut off:
On the slave i am getting the following data for 1 of the checks:
On the central i see the following:
I thought the nrdp protocol isn't limited in what its sending to the central. It seems this is happening with multiple checks that all have long outputs.
check_multi::check_multi::plugins=6 time=0.177073 'perf-disk space::check_disk::/'=2558MB;9240;10395;0;11551 /lib/init/rw=0MB;200;225;0;251 /dev=0MB;196;221;0;246 /dev/shm=0MB;200;225;0;251 'perf-current users::check_users::users'=1;20;50;0 'perf-current load::check_load::load1'=0.000;5.000;10.000;0; load5=0.040;4.000;6.000;0; load15=0.070;3.000;4.000;0; svc-http::check_http::time=0.003670s;;;0.000000 size=453B;;;0
check_multi::check_multi::plugins=6 time=0.177073 perf-disk space::check_disk::/=2558MB;9240;10395;0;11551 /lib/init/rw=0MB;200;225;0;251 /dev=0MB;196;221;0;246 /dev/shm=0MB;200;225;0;251 perf-current users::check_users::users=1;20;50;0 perf-current load:
I'll have to take a look at that one. Not sure where exactly it's getting cut off, but your string is being cut off at exactly 255 bytes.
To be sure i checked the slave results and they are all fine. The problem lies between the communication of the slave and central.
Is there more information about this available?
