Error: Service has no hosts and/or service_description
valmberg
Post by valmberg »
Running Nagios XI in VMware.
After upgrading to Nagios 5.3.x, I am unable to successfully apply any configurations when I add/change services. No services work - no matter what I do. I have followed several threads and attempted to fix the problem. I am now down to having deactivated ALL of the services in Nagios - then I get no services defined error message.
I have also gone through all the steps of Config File Management (delete files, then write files, then verify files) and have gotten it to successfully verify. However, whenever I go to add a service - JUST ONE SERVICE, I get the error message: "Error: Service has no hosts and/or service_description..." If I remove the LAST service, I get an error saying there are no services configured.
Here is the full text of the message:
Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/Censdcprd1.cfg', starting on line 16)
Nagios Core 4.1.1
Last Modified: 08-19-2015
License: GPL
Reading configuration data...
Read main config file okay...
Please help. Up until now, Nagios XI has been very reliable and dependable. I have successfully upgraded and kept the server upgraded until the 5.3.x release. I have also tried to go into the Nagios XI customer forum, but it says I don't have access - even though we have support through Nagios.
Reason: Please use code tags for output.
avandemore
Re: Error: Service has no hosts and/or service_description
Post by avandemore »
Please go to XI > Configure > CCM > Configuration Snapshots > and find the most recent entry with "Config Ok". Click the Restore button for that line. Restore the snapshot then apply the configuration. Let us know if that helped.
Previous Nagios employee
valmberg
Post by valmberg »
I tried that and it still is throwing errors when working with services. I still get the same error : "Error: Service has no hosts and/or service_description"
Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/Tilsdcprd1.cfg', starting on line 105)
Nagios Core 4.1.1
License: GPL
And here is the Tilsdcprd1 config file:
# Service configuration file
# Created by: Nagios Core Config Manager 2.6.2
# Date:	      2016-11-23 12:57:46
# Version:    Nagios 3.x config file
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
	service_description		CPU Usage
	use				xiwizard_windowswmi_service
	check_command			check_xi_service_wmiplus!'oya.ad/wmiagent'!'Lisa1984'!checkcpu!-w '80' -c '90'
	max_check_attempts		5
	check_interval			5
	retry_interval			1
	check_period			xi_timeperiod_24x7
	notification_interval		60
	notification_period		xi_timeperiod_24x7
	contact_groups			Tier II,Tier III
	_xiwizard			windowswmi
	register			1
	service_description		Drive C: Disk Usage
	check_command			check_xi_service_wmiplus!'oya.ad/wmiagent'!'Lisa1984'!checkdrivesize!-a 'C': -w '80' -c '95'
	check_interval			5
	retry_interval			1
	register			1
	service_description		Drive D: Disk Usage
	check_command			check_xi_service_wmiplus!'oya.ad/wmiagent'!'Lisa1984'!checkdrivesize!-a 'D': -w '80' -c '95'
	check_interval			5
	retry_interval			1
	register			1
	service_description		Memory Usage
	check_command			check_xi_service_wmiplus!'oya.ad/wmiagent'!'Lisa1984'!checkmem!-s physical -w '80' -c '90'
	check_interval			5
	retry_interval			1
	register			1
	service_description		Page File Usage
	check_command			check_xi_service_wmiplus!'oya.ad/wmiagent'!'Lisa1984'!checkpage!-w '80' -c '90'
	check_interval			5
	retry_interval			1
	register			1
	service_description		Ping
	use				xiwizard_windowsserver_ping_service
	check_interval			5
	retry_interval			1
	register			1
	service_description		Uptime
	check_command			check_xi_service_wmiplus!'oya.ad/wmiagent'!'Lisa1984'!checkuptime!-w '7776000' -c '10368000'!!!!
	check_interval			5
	retry_interval			1
	notification_interval		1440
	register			1
# END OF FILE
valmberg
Post by valmberg »
Here is my Nagios XI Installation Profile (attached)
Reason: removing profile for security purposes
valmberg
Post by valmberg »
If I go to Config File Management and click "Verify Files", I get the "Things Look Okay" message:
Nagios Core 4.1.1
License: GPL
Checking objects...
Checked 170 services.
Warning: Host 'UAG' has no default contacts or contactgroups defined!
Checked 100 hosts.
Checked 8 host groups.
Checked 9 service groups.
Checked 10 contacts.
Checked 5 contact groups.
Checked 127 commands.
Checked 16 time periods.
Checked 0 host escalations.
Checked 100 hosts
Checked 0 host dependencies
Checked 16 timeperiods
Checking misc settings...
Total Warnings: 1
Total Errors: 0
However, if I click "write Configs" then "delete configs" and then "write configs" and "verify files", I get the Error: Service has no hosts and/or service_description message.
valmberg
Post by valmberg »
And if I remove the host from the service and put in the '*', it applies the configuration and checks the service on all hosts (*)
avandemore
Please repeat my earlier suggestion: https://support.nagios.com/forum/viewto ... 11#p203777
However this time do a Delete Files immediately prior to that.
valmberg
Post by valmberg »
I did exactly as you suggested. Everything came back OK.
Here is the restore and the message after I apply configuration:
Write host configurations ...
Host configuration files successfully written!
Write service configurations ...
Service configuration files successfully written!
Configuration file: hostgroups.cfg successfully written!
Configuration file: servicegroups.cfg successfully written!
Configuration file: hosttemplates.cfg successfully written!
Configuration file: servicetemplates.cfg successfully written!
Configuration file: timeperiods.cfg successfully written!
Configuration file: commands.cfg successfully written!
Configuration file: contacts.cfg successfully written!
Configuration file: contactgroups.cfg successfully written!
Configuration file: contacttemplates.cfg successfully written!
Configuration file: servicedependencies.cfg successfully written!
Configuration file: hostdependencies.cfg successfully written!
Configuration file: serviceescalations.cfg successfully written!
Configuration file: hostescalations.cfg successfully written!
Configuration file: serviceextinfo.cfg successfully written!
Configuration file: hostextinfo.cfg successfully written!
HOWEVER, after the successful "Apply Configuration", I go into a service and make a change on the service (a minor change), it returns the message Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/Cenvapprd51.oya.ad.cfg', starting on line 16)" after I apply configuration again.
Post by dwhitfield »
