Procedure to install Nagios core on AIX servers
vyas
Post by vyas »
Need Procedure to install nagios core on AIX servers and also how to add AIX server to Nagios monitoring server
Re: Procedure to install Nagios core on AIX servers
Post by dwhitfield »
Do you mean monitor AIX or actually install on AIX?
As for installing on AIX, there is an open bug for that: https://github.com/NagiosEnterprises/ncpa/issues/258
Older versions of Core and AIX can be made to work together, so I guess I will ask this...what version of Core are you wanting to use? Of course, older versions have bugs that have been fixed, so it isn't recommended.
I want to let you know that we will be closed tomorrow and Friday, due to US Thanksgiving. Thus, you are likely not to get a response from us until Monday. I just wanted to give you a heads up. Thanks for using the forums!
