Backup snapshots not being created
ianginn
Post by ianginn »
I'm having an issue with my cluster. I want to set up backup snapshots but they are not being generated. Both servers in the cluster have access to a NFS share where I want the backups to be created. It's mounted to the same path with the same permissions on both servers. The directories have the owner as nagios:users and the nagios user can write to this directory without issue. Before I added a second server to the cluster my backups were working fine.
Re: Backup snapshots not being created
Post by mcapra »
Which version of Nagios Log Server are you using?
Can you also share a screenshot of your Backup & Maintenance page?
ianginn
Post by ianginn »
This topic can be closed. It looks like some of the changes I made yesterday worked and I didn't see that the backups run at noon. They are working now, thanks!
Sounds good - closing this one out.
