how can monitor url website with check_ping on windows clien
baber
Post by baber »
Dear all
i have a website and many virtual machine that just via one of my virtual machine (vm1) that host have to open and vm1 is windows os now i want to know
can i use this script :
https://github.com/catinello/nagios-check-website
can this script run on nagios server and first connect to vm1(windows os) and then via that chk my website can be open or not?
BR
Re: how can monitor url website from nagios via other VM
As it's a third party plugin, it's hard to say. At a quick glance though it appears to be bash which I don't think will run properly on Windows yet.
baber
Post by baber »
rkennedy wrote:As it's a third party plugin, it's hard to say. At a quick glance though it appears to be bash which I don't think will run properly on Windows yet.
This is my plan
I have a server that os is windows server2008 now i can this server completely from nagios such as disk space cpu memory and .... now i have a website that this server just can access to that now i want just check http or check website url that sure website is ok and that server has access that i thought perhaps nagios server can connect to that server and then check url or check website that is ok or not now can i do this with nagios or if can not use this way what solution do you have for monitor that website url from a server??
BR
Take a look at this link to see if this would work for you.
https://exchange.nagios.org/directory/P ... pe/details
avandemore
Post by avandemore »
See example 2b. https://assets.nagios.com/downloads/nag ... e/NRPE.pdf
You would need to find some Windows equivalent of check_http so that NSClient can run it, or install a Unix/Linux VM on the 2008 server and run it from there.
Previous Nagios employee
baber
Post by baber »
So thanks
check_ping.bat is ok for me but when i run this plugin on windows client it is ok
check_ping.bat google.com
OK: Ping succeded
but now i want it chk automatically from nagios
i have added this line to nsclient.ini file :
i have attached nasclient.ini file
check_web_up = check_ping.bat google.com
and on that server.cfg file add this service
use          		 generic-service
host_name      		 Topup-Service
service_description      website
check_command       	 check_nrpe!check_ping
but not work and appear this message on nagios
Unknown command(s): check_ping
nsclient.ini
(15.54 KiB) Downloaded 276 times
avandemore
Re: how can monitor url website with check_ping on windows c
We don't write or maintain NSClient, nor do we support custom plugins. That being said, here are some pointers:
You defined a command check_web_up. Then you called a command check_nrpe!check_ping. This most likely should be check_nrpe!check_web_up along with ensuring NSClient has been restarted after the configuration change. For further assistance with this topic, please consult the document I linked to previously and the NSClient website https://www.nsclient.org/.
baber
Post by baber »
avandemore wrote:We don't write or maintain NSClient, nor do we support custom plugins. That being said, here are some pointers:
so thanks
my problem has been solved
BR
