Hello, i have trouble with services. If service is down i can get three emails notifications by one event (attached screen). I did not find duplicates of its services in my config files.
What it can be? May be i need a flap settings?
Notifications from service
Re: Notifications from service
At a quick glance it seems you may have multiple processes running. What is the full output of ps -ef | grep nagios?
Also, please post your /usr/local/nagios/var/objects.cache for us to review.
Hi, here please:
In some places i changed my IP
Since that time I have rebooted nagios.
nagios 22098 1 0 Oct06 ? 00:43:35 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 22100 22098 0 Oct06 ? 00:02:23 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 22101 22098 0 Oct06 ? 00:02:25 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 22102 22098 0 Oct06 ? 00:02:27 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 22103 22098 0 Oct06 ? 00:02:34 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 22104 22098 0 Oct06 ? 00:02:26 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 22105 22098 0 Oct06 ? 00:02:14 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 22106 22098 0 Oct06 ? 00:02:18 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 22107 22098 0 Oct06 ? 00:02:28 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 22108 22098 0 Oct06 ? 00:02:34 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 22109 22098 0 Oct06 ? 00:02:18 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 22110 22098 0 Oct06 ? 00:02:24 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 22111 22098 0 Oct06 ? 00:02:32 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 22112 22098 0 Oct06 ? 00:02:22 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 23932 1 0 Oct31 ? 00:23:49 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 23934 23932 0 Oct31 ? 00:01:04 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 23935 23932 0 Oct31 ? 00:01:05 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 23936 23932 0 Oct31 ? 00:01:07 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 23937 23932 0 Oct31 ? 00:01:06 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 23938 23932 0 Oct31 ? 00:01:05 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 23939 23932 0 Oct31 ? 00:01:05 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 23940 23932 0 Oct31 ? 00:01:05 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 23941 23932 0 Oct31 ? 00:01:06 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 23942 23932 0 Oct31 ? 00:01:04 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 23943 23932 0 Oct31 ? 00:01:05 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 23944 23932 0 Oct31 ? 00:01:04 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 23945 23932 0 Oct31 ? 00:01:05 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 23985 23932 0 Oct31 ? 00:01:15 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 24048 1 0 Nov28 ? 00:00:13 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 24050 24048 0 Nov28 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 24051 24048 0 Nov28 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 24052 24048 0 Nov28 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 24053 24048 0 Nov28 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 24054 24048 0 Nov28 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 24055 24048 0 Nov28 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 24056 24048 0 Nov28 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 24057 24048 0 Nov28 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 24058 24048 0 Nov28 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 24059 24048 0 Nov28 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 24060 24048 0 Nov28 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 24061 24048 0 Nov28 ? 00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios 24065 24048 0 Nov28 ? 00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 31804 23938 0 03:02 ? 00:00:00 /usr/local/nagios/libexec/check_ping -H 138.201.x.x -w 100.0,20% -c 500.0,60% -p 5
nagios 31806 23943 0 03:02 ? 00:00:00 /usr/local/nagios/libexec/check_ping -H 148.251.x.x -w 100.0,20% -c 500.0,60% -p 5
nagios 31809 31806 0 03:02 ? 00:00:00 /bin/ping -n -U -w 10 -c 5 148.251.x.x
nagios 31810 31804 0 03:02 ? 00:00:00 /bin/ping -n -U -w 10 -c 5 138.201.x.x
nagios 31847 23943 0 03:02 ? 00:00:00 /usr/local/nagios/libexec/check_ping -H 88.198.x.x -w 3000.0,80% -c 5000.0,100% -p 5
nagios 31848 31847 0 03:02 ? 00:00:00 /bin/ping -n -U -w 30 -c 5 88.198.x.x
root 31855 31630 0 03:02 pts/0 00:00:00 grep nagios- Attachments
objects.txt- (162.25 KiB) Downloaded 404 times
Your configuration looks fine, but the ps suggests you had multiple processes running.
I would kill off all of the duplicates, and ensure just one is running. The worker processes are fine, as long as they spawn from the parent, but here it seems there are multiple running.
Thanks a lot! It's helped.
- Former Nagios Staff
It sounds like this issue has been resolved. Is it okay if we lock this thread? Thanks for choosing the Nagios forums!
