Performance counter monitoring not working
Hi Team I am getting error for logicalDisk(_Total)\\Avg. Disk sec/Transfer parameter.
I have configured it like this
check command check_nrpe
command view $USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c $ARG1$ $ARG2$
ARG1 CheckCounter
ARG2 -a "Counter=\\logicalDisk(_Total)\\Avg. Disk sec/Transfer" ShowAll MinWarn=40 MinCrit=45
Error : Failed to poll counter: \\logicalDisk(_Total)\\Avg. Disk sec/Transfer Failed to poll counter \\logicalDisk(_Total)\\Avg. Disk sec/Transfer: c0000bc6: The data is not valid.
Kindly help to fix it.
Target windows machine is Windows 2003 SP2. Screenshot of performance monitor is as attached.
Please note, same command works fine for win2008 servers onwards...
ARG1 CheckCounter
Reason: marking with green check mark
Re: Performance counter monitoring not working
What version of NSClient++ are you using? You may need to do some further escaping as this may be related - https://github.com/mickem/nscp/issues/4 ... t-63267894
The other option is trying to upgrade your NSClient++, or trying a different version.
We are using NSCP-0.5.0.62-Win32. And below is the command
[[email protected] ~]# /usr/local/nagios/libexec/check_nrpe -H xx.xx.xx.xx -t 30 -c CheckCounter -a "Counter=:logicalDisk(_Total):Avg. Disk sec/Transfer"
Failed to get value
Failed to get value
Try and rebuild the counters on your Windows server to see if that fixes the error.
Login as an administrator on that server and run this in a command prompt.
Let us know if it works.
cd c:\windows\system32
lodctr /RBe sure to check out our Knowledgebase for helpful articles and solutions!
I rebuilt the counters and tried again. But no luck. Its the same
Failed to get value
Failed to get value
Try the examples below and see if you can get any results from your server for these counters.
/usr/local/nagios/libexec/check_nrpe -H xxx.xxx.xxx.xxx -t 30 -c CheckCounter -a "Counter=\\\\VNMSSCTX07\\logicalDisk(_Total)\\Avg. Disk sec/Transfer" ShowAll MinWarn=40 MinCrit=45
/usr/local/nagios/libexec/check_nrpe -H xxx.xxx.xxx.xxx -t 30 -c CheckCounter -a "Counter=\\logicalDisk(_Total)\\Avg. Disk sec/Transfer" ShowAll MinWarn=40 MinCrit=45Be sure to check out our Knowledgebase for helpful articles and solutions!
still the same,
[[email protected] libexec]# ./check_nrpe -H xx.xx.xx.xx -t 30 -c CheckCounter -a "Counter=\\\\VNMSSCTX07\\logicalDisk(_Total)\\Avg. Disk sec/Transfer" ShowAll MinWarn=40 MinCrit=45
Failed to poll counter: \\VNMSSCTX10\logicalDisk(_Total)\Avg. Disk sec/Transfer Failed to poll counter \\VNMSSCTX07\logicalDisk(_Total)\Avg. Disk sec/Transfer: c0000bc6: The data is not valid.
[[email protected] libexec]# ./check_nrpe -H xx.xx.xx.xx -t 30 -c CheckCounter -a "Counter=\\logicalDisk(_Total)\\Avg. Disk sec/Transfer" ShowAll MinWarn=40 MinCrit=45
Failed to poll counter: \logicalDisk(_Total)\Avg. Disk sec/Transfer Failed to poll counter \logicalDisk(_Total)\Avg. Disk sec/Transfer: c0000bc6: The data is not valid.
I don't believe the newest NSClient++ is going to work well with Windows 2003 SP2, you will more than likely need to try 0.3.9 as a version which should work.
It appears to be working fine on my end -
[root@localhost tmp]# /usr/local/nagios/libexec/check_nrpe -H 192.168.47.8 -t 30 -c CheckCounter -a "Counter=\\logicalDisk(_Total)\\Avg. Disk sec/Transfer" ShowAll MinWarn=40 MinCrit=45
CRITICAL: \logicalDisk(_Total)\Avg. Disk sec/Transfer = 0|'\logicalDisk(_Total)\Avg. Disk sec/Transfernone'=0;40;45
I installed NSClient++ 0.3.9 and tried.
Avg. Disk sec/Transfer works fine with check_nt and not with check_nrpe.
The other services where we used check_nrpe is not working.
We have attached the NSC configuration file and the screen shot of other services using check_nrpe
getting error " UNKNOWN: No handler for that command"
When you switched from 0.5.0 -> 0.3.9, the configuration file switched from nsclient.ini to NSC.ini - you'll want to take this into account and adjust your external commands accordingly.
