Nagios XI Admin Login Reset
GacoAdmin110
Post by GacoAdmin110 »
Good Afternoon,
One of my site admins has reset the Admin account to log into the command line/Centos OS for my Nagios XI server.
The web portal works just fine, but I need to log into the command line to do some cleanup & adjust disk size.
Is there anyway to log into the command line to reset the password? I have tried root, nagiosxi, and nagiosadmin accounts with the defaults & our own known passwords...no luck.
Thnx much
Mike
Re: Nagios XI Admin Login Reset
Post by dwhitfield »
If I understand the situation correctly, you are going to need to talk to the site admin that changed the password.
Just to clarify though, everything in Nagios works fine, correct?
GacoAdmin110
Yes, everything is working correctly through the web console.
Unfortunately that particular site admin is no longer with us so I have to find another way. Or I will have to do a full backup & redo the server entirely...ugh.
Thnx
You can try something like this:
https://access.redhat.com/documentation ... asswd.html
But I need to stress that this is out of scope of our support and is not guaranteed/recommended/suggested/etc.
chadw
Post by chadw »
I would like to add to this discussion:
We just terminated an employee who had only setup himself as administrator, no one else has ANY access. We cannot login to the web portal, is there a way around this? We may have the root password to the CentOS box.
Thanks!!
If you do have access, there is a reset script located at /usr/local/nagiosxi/scripts/reset_nagiosadmin_password.php:
[root@localhost scripts]# ./reset_nagiosadmin_password.php
Nagios XI Admin Password Reset Tool
Copyright (c) 2016 Nagios Enterprises, LLC
Usage: ./reset_nagiosadmin_password.php --password=<newpassword>
Resets password used to login to the Nagios XI interface as the nagiosadmin user.
chadw
Post by chadw »
You ROCK!!!
I do what I can :)
Going to lock this up now though since the web account reset script has been shared, and we can't much help with a locked-out root account.
