Hello Team,
Earlier we used to monitor our linux machines with nrpe agent and following services are being monitored.
Disk Space, CPU, Memory, Load and all services.
Due to some issue we switched to SNMP monitoring and we are not able to find the load and running services status. Please suggest the steps to monitor the load and services status with SNMP monitoring.
-Mohan
Some of the services monitoring is missing with SNMP monitor
steelwedge
Re: Some of the services monitoring is missing with SNMP mon
I think this is the document you're looking for, which has instructions how to do so - https://assets.nagios.com/downloads/nag ... g_SNMP.pdf
steelwedge
I followed the same document and there are no instructions on how to monitor the load of the server using SNMP, please check and update.
https://assets.nagios.com/downloads/nag ... 1446043558
What problem did you have with the Linux SNMP wizard? Can you show us screenshots?
steelwedge
We have below hadoop services running and their names as below, please let us know how to monitor these services whether they are up and running or not using SNMP.
ntp
hadoop-hdfs-namenode
impala-state-store
impala-catalog
kudu-master
hive-metastore
mysql
ntp
hadoop-hdfs-datanode
impala-server
kudu-tserver
ntp
impala-state-store
impala-catalog
kudu-master
hive-metastore
mysql
ntp
impala-server
kudu-tserver
Please follow the document I previously linked, as it outlines how to do exactly this with the 'Linux SNMP Wizard'. If you are experiencing issues, please show us in the form of screenshots what you're seeing.
