iptables bug
zeero22
iptables bug
Post by zeero22 »
NNA version 2.2.3
When adding and removing sources from the web interface, the iptables rules are not updated correctly.
"iptables -nvL" output shows many duplicate entries.
I have manually removed the duplicates, but perhaps you can look at addressing this issue in the next patch.
Regards
Zee
bwallace
Re: iptables bug
Post by bwallace »
I was able to reproduce this behavior here as well, using NNA 2.2.3 on CentOS 7.1.
I have filed a bug report on it = TASK ID 10268
Thanks for bringing this to our attention, are there any other questions or may we lock this thread?
