I would like to know how may I change the number of "Intentos" I attached in my picture. Probably it is very easy but I do not get to changing it.
Thank you
Problem nagios xi
Problem nagios xi
Re: Problem nagios xi
Heh, 1/5 means the 1st attempt of 5 was successful in the 1st line for example.
I define this in a template for hosts and services so its kept in few places, but have a look at a host or service definition, 2nd tab (check settings), its the 3rd text box down on the left. In English its labelled max check attempts.
- Former Nagios Staff
@gormank is absolutely right. Thanks!
I've also attached a screenshot that may be useful for setting this up on a per-host basis. The 55 in my screenshot is the one you want to change. Please let us know if you'd like to do this in bulk.
I guessed Spanish, but is your setup in Portuguese?
