Monitoring MySQL
Cristhian_Plaza
Monitoring MySQL
Hi, me again I don't want bother a lot but I'm almost new with Nagios and there are a lot of things that I don't understand, I want to monitor MySQL and I installed this plugin, https://exchange.nagios.org/directory/P ... rs/details (check_mysql_counters), the plugin's introduction is amazing I really find it useful, but the answer I got from it is, (No output on stdout) stderr: execvp(check_mysql_counters_55, ...) failed. errno is 2: No such file or directory, I don't know what is the problem, if I did a wrong install or if it's talking about another kind of error. Anyway, I want to monitor MySQL and I don't find the best thing of do it. I need help.
- Former Nagios Staff
Re: Monitoring MySQL
Since we do not write that plugin, our support of it will be limited.
That plugin probably does work with 4.x, but it is not listed as such. You can find a list of MySQL plugins tested against 4.x at https://exchange.nagios.org/directory/A ... hR/1/15107
What exactly are you trying to check? That will help us direct you to the correct plugin. Also, I should mention that there is a MySQL wizard built in to Nagios XI.
Lastly, what version of Core are you using, and on what OS/version are you running it? That will help us determine where you should install plugins and which commands you should be using. Thanks!
jasonholtzapple
The error message makes me think the plugin might not be installed correctly. I haven't tried the plugin with Nagios 4, but it should work. There is a large amount of performance data returned, so you will not be able to use it with NRPE - you need to contact the database directly from your Nagios monitoring host.
Cristhian_Plaza
What I want to monitor?. All that could be possible, maybe number of connections, capacity of the server, number of queries, number of tables, number of errors, I don't know, I'm not an expert on databases but the idea is can control an application from Nagios, Now which version of Core am I using?, I am using Nagios Core 4.2.0 on a Red Hat 7 on AWS.dwhitfield wrote:Since we do not write that plugin, our support of it will be limited.
Cristhian_Plaza
Yes I am calling it directly. I'm not using NRPE.jasonholtzapple wrote:The error message makes me think the plugin might not be installed correctly. I haven't tried the plugin with Nagios 4, but it should work. There is a large amount of performance data returned, so you will not be able to use it with NRPE - you need to contact the database directly from your Nagios monitoring host.
Can you post your /etc/httpd/conf.d/pnp4nagios.conf? Thanks!
Thanks for jumping in @jasonholtzapple!
Cristhian_Plaza
dwhitfield wrote:Can you post your /etc/httpd/conf.d/pnp4nagios.conf? Thanks!
# SAMPLE CONFIG SNIPPETS FOR APACHE WEB SERVER
Alias /pnp4nagios "/usr/local/pnp4nagios/share"
<Directory "/usr/local/pnp4nagios/share">
AllowOverride None
Order allow,deny
Allow from all
# Use the same value as defined in nagios.conf
AuthName "Nagios Access"
AuthType Basic
AuthUserFile /usr/local/nagios/etc/htpasswd.users
Require valid-user
<IfModule mod_rewrite.c>
# Turn on URL rewriting
RewriteEngine On
Options FollowSymLinks
# Installation directory
RewriteBase /pnp4nagios/
# Protect application and system files from being viewed
RewriteRule ^(application|modules|system) - [F,L]
# Allow any files or directories that exist to be displayed directly
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
# Rewrite all other URLs to index.php/URL
RewriteRule .* index.php/$0 [PT,L]
</IfModule>
</Directory>
Is this set up on your production server, the test server, or a different server? Is the setup the same as when you were having the SNMP issue?
avandemore
Please show the full command and output as it relates to your error. Example:
[root@avandemore-centos7 etc]# /usr/local/nagios/libexec/check_nrpe -H 192.168.3.156
I (0.4.4.19 2015-12-08) seem to be doing fine...Previous Nagios employee
Cristhian_Plaza
Yes the problem is with my production server. Jajjajaaj when solved a problem another one appear.dwhitfield wrote:Is this set up on your production server, the test server, or a different server? Is the setup the same as when you were having the SNMP issue?
