We are running Nagios XI 5.2.9 on centos-7 64 bit which is on Virtual machine.
We installed VMware SDK 5.5.2 64 bit successfully in Nagios XI and added one windows 7 VM for testing. it shows services are critical as shown below:
ESX3 CRITICAL - Error connecting to server at 'https://10.111.98.38/sdk/webService': Connection refused
Please find the screen shot for reference.
Nagios XI VM ESX3 - Connection refused
[email protected]
Re: Nagios XI VM ESX3 - Connection refused
Is 10.111.98.38 the proper IP for the VMWare server, or is this perhaps the IP of the Windows machine?
From the CLI of Nagios, can you run the following and post the output?
This should help to see what's open on the machine.
nmap 10.111.98.38
[email protected]
Thank you for the update.
Actually we added wrong VM host.
Now we added correct one no issues with that.
- Former Nagios Staff
It sounds like this issue has been resolved. Is it okay if we lock this thread? Thanks for choosing the Nagios forums!
