I'm using Nagios 4.2.3, and NRPE 3.0.1
I think this used to work with my nagios 3.x implementation.
Nagios setup:
use generic-service-intorrent
host_name vm25ainst
service_description ADE
check_command check_nrpe_long!check_ADE
command_name check_nrpe_long
command_line /usr/local/nagios/libexec/check_nrpe -H $HOSTADDRESS$ -t 25:CRITICAL -c $ARG1$
command[check_ADE]=/usr/libexec/check_ADE
(I added a little debug to nrpe to help determine problems)
Incorrect command line arguments supplied.
Given: /usr/local/nagios/libexec/check_nrpe -H 192.168.134.220 -t 25 -c check_ADE
NRPE Plugin for Nagios
Copyright (c) 1999-2008 Ethan Galstad ([email protected])
Version: 3.0.1
Looking at the nagios debug log, I see this:
[code]
[1480693147.637895] [2048.2] [pid=121224] Uncleaned macro. Running output (83): '/usr/local/nagios/libexec/check_nrpe -H 192.168.134.220 -t 25:CRITICAL -c check_ADE'
[1480693147.637904] [2048.2] [pid=121224] Just finished macro. Running output (83): '/usr/local/nagios/libexec/check_nrpe -H 192.168.134.220 -t 25:CRITICAL -c check_ADE'
[1480693147.637913] [2048.2] [pid=121224] Processing part: ''
[1480693147.637922] [2048.2] [pid=121224] Not currently in macro. Running output (83): '/usr/local/nagios/libexec/check_nrpe -H 192.168.134.220 -t 25:CRITICAL -c check_ADE'
[1480693147.637931] [2048.1] [pid=121224] Done. Final output: '/usr/local/nagios/libexec/check_nrpe -H 192.168.134.220 -t 25:CRITICAL -c check_ADE'
[1480693147.637939] [2048.1] [pid=121224] **** END MACRO PROCESSING *************
but check_nrpe says the :CRITICAL was removed...
What do I do to get around this?
wrapping the 25:CRITICAL in quotes doesn't help.
