Network Dependencies
chandasandeep
Post by chandasandeep »
Hi Team,
We are using Nagios Core for monitoring Tool. Recently we have faced an issue between two data centers which causes to getting the alerts from second data center as its different network.
so , i tried to give the configuration set up as given below and found that error while restarting the nagios service.
Could you please help me out asap
define hostdependency{
host_name Host A
dependent_host_name 10.175.23.1
notification_failure_criteria d
host_name Host B
notification_failure_criteria d,u
Note : Error which we are recieving like as given blow.
[root@azmrns01 hosts]# service nagios restart
Restarting nagios (via systemctl): Job for nagios.service failed because the control process exited with error code. See "systemctl status nagios.service" and "journalctl -xe" for details.
[FAILED]
[root@azmrns01 hosts]# tail -f /var/log/messages
Dec 5 04:31:42 azmrns01 nagios: Check your configuration file(s) to ensure that they contain valid
Dec 5 04:31:42 azmrns01 nagios: directives and data defintions. If you are upgrading from a previous
Dec 5 04:31:42 azmrns01 nagios: version of Nagios, you should be aware that some variables/definitions
Dec 5 04:31:42 azmrns01 nagios: may have been removed or modified in this version. Make sure to read
Dec 5 04:31:42 azmrns01 nagios: the HTML documentation regarding the config files, as well as the
Dec 5 04:31:42 azmrns01 nagios: 'Whats New' section to find out what has changed.
Dec 5 04:31:42 azmrns01 systemd: nagios.service: control process exited, code=exited status=8
Dec 5 04:31:42 azmrns01 systemd: Failed to start LSB: Starts and stops the Nagios monitoring server.
Dec 5 04:31:42 azmrns01 systemd: Unit nagios.service entered failed state.
Dec 5 04:31:42 azmrns01 systemd: nagios.service failed.
avandemore
Re: Network Dependencies
Post by avandemore »
What is the output from:
/usr/local/nagios/bin/nagios -vvv /usr/local/nagios/etc/nagios.cfg
Previous Nagios employee
chandasandeep
Hi Thanks for your reply,
Here are the out put details as given below.
My requirement is to configure network dependencies. we have linux servers in two data centers with different network. one data center xyz and nagios is set up in same data center, when vpn disconnected second data center servers are getting server down alerts from nagios.
So i tried to configure as given below.
[root@azmrns01 hosts]# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.0.8
Last Modified: 08-12-2014
License: GPL
Reading configuration data...
Read main config file okay...
Warning: Duplicate definition found for service 'disk write queue length' on host 'TDMRAXSQL01' (config file '/usr/local/nagios/etc/objects/hosts/TDMRAXSQL01.cfg', starting on line 218)
Warning: Duplicate definition found for service 'disk read queue length' on host 'TDMRAXSQL01' (config file '/usr/local/nagios/etc/objects/hosts/TDMRAXSQL01.cfg', starting on line 209)
Warning: Duplicate definition found for service 'disk write queue length' on host 'TDMRAXDEVSQL01' (config file '/usr/local/nagios/etc/objects/hosts/TDMRAXDEVSQL01.cfg', starting on line 218)
Warning: Duplicate definition found for service 'disk read queue length' on host 'TDMRAXDEVSQL01' (config file '/usr/local/nagios/etc/objects/hosts/TDMRAXDEVSQL01.cfg', starting on line 209)
Warning: Duplicate definition found for service 'disk write queue length' on host 'TDMRSQL01' (config file '/usr/local/nagios/etc/objects/hosts/TDMRSQL01.cfg', starting on line 233)
Warning: Duplicate definition found for service 'disk read queue length' on host 'TDMRSQL01' (config file '/usr/local/nagios/etc/objects/hosts/TDMRSQL01.cfg', starting on line 224)
Warning: Duplicate definition found for service 'data buffer cache hit ratio' on host 'TDMRSQL01' (config file '/usr/local/nagios/etc/objects/hosts/TDMRSQL01.cfg', starting on line 198)
Warning: Duplicate definition found for service 'SQL connection time' on host 'TDMRSQL01' (config file '/usr/local/nagios/etc/objects/hosts/TDMRSQL01.cfg', starting on line 190)
Warning: Duplicate definition found for service 'disk write queue length' on host 'AZMRAXSQL01' (config file '/usr/local/nagios/etc/objects/hosts/AZMRAXSQL01.cfg', starting on line 213)
Warning: Duplicate definition found for service 'disk read queue length' on host 'AZMRAXSQL01' (config file '/usr/local/nagios/etc/objects/hosts/AZMRAXSQL01.cfg', starting on line 204)
Warning: Duplicate definition found for service 'sql service CPU privileged time' on host 'TDMRAXDW01' (config file '/usr/local/nagios/etc/objects/hosts/TDMRAXDW01.cfg', starting on line 295)
Warning: Duplicate definition found for service 'disk write queue length' on host 'TDMRAXDW01' (config file '/usr/local/nagios/etc/objects/hosts/TDMRAXDW01.cfg', starting on line 204)
Warning: Duplicate definition found for service 'disk read queue length' on host 'TDMRAXDW01' (config file '/usr/local/nagios/etc/objects/hosts/TDMRAXDW01.cfg', starting on line 195)
Warning: Duplicate definition found for service 'disk write queue length' on host 'TDMRSRS01' (config file '/usr/local/nagios/etc/objects/hosts/TDMRSRS01.cfg', starting on line 249)
Warning: Duplicate definition found for service 'disk read queue length' on host 'TDMRSRS01' (config file '/usr/local/nagios/etc/objects/hosts/TDMRSRS01.cfg', starting on line 240)
Warning: Duplicate definition found for service 'disk write queue length' on host 'TDMRSQL02' (config file '/usr/local/nagios/etc/objects/hosts/TDMRSQL02.cfg', starting on line 221)
Warning: Duplicate definition found for service 'disk read queue length' on host 'TDMRSQL02' (config file '/usr/local/nagios/etc/objects/hosts/TDMRSQL02.cfg', starting on line 212)
Warning: Duplicate definition found for service 'disk write queue length' on host 'AZMRDEVAXSQL01' (config file '/usr/local/nagios/etc/objects/hosts/AZMRDEVAXSQL01.cfg', starting on line 199)
Warning: Duplicate definition found for service 'disk read queue length' on host 'AZMRDEVAXSQL01' (config file '/usr/local/nagios/etc/objects/hosts/AZMRDEVAXSQL01.cfg', starting on line 190)
Warning: Duplicate definition found for service 'disk write queue length' on host 'TDMRAXSQL02' (config file '/usr/local/nagios/etc/objects/hosts/TDMRAXSQL02.cfg', starting on line 220)
Warning: Duplicate definition found for service 'disk read queue length' on host 'TDMRAXSQL02' (config file '/usr/local/nagios/etc/objects/hosts/TDMRAXSQL02.cfg', starting on line 211)
Error: Invalid max_check_attempts value for host 'gateway'
Error: Could not register host (config file '/usr/local/nagios/etc/objects/hosts/host-gateway.cfg', starting on line 2)
[root@azmrns01 hosts]# more host-gateway.cfg
# a host definition for the gateway of the default route
define host {
host_name gateway
alias Default Gateway
address 10.175.23.1
use generic-host
Sandeep
avandemore
That's a pretty clear error as to what is happening:
Please see this: https://assets.nagios.com/downloads/nag ... .html#host
You'll notice max_check_attempts is a required value. So either adjust that definition or assign it a template it inherit the value from.
chandasandeep
Hi Thank you for assistance.
successfully i have configured gateway
[root@azmrns01 hosts]# cat host-gateway.cfg
host_name Gateway
alias Bogus Router #1
address 10.175.23.81
check_interval 1
retry_interval 1
max_check_attempts 5
check_period 24x7
process_perf_data 0
retain_nonstatus_information 0
contact_groups admins
notification_interval 2
notification_period 24x7
notification_options d,u,r
and here are dependencies in same gateway config file.
host_name AZMRDC01
dependent_host_name Gateway
host_name TDMRAXDEVSQL01
Note : My question is when vpn disconnected between AZMRDC01 and TDMRAXDEVSQL01 network. we have to get host unreachable or etc alerts on TDMRAXDEVSQL01 server. please let me know where and how should i place set up.
thanks in advance.
Sandeep
avandemore
If I understand your setup correctly you have something like this:
TDMRAXDEVSQL01+---------+Gateway(VPN)+---------+AZMRDC01
If this the case, the Gateway VPN software should be exposing some type of VPN status information.
If it was me, I'd find a plugin for that on https://exchange.nagios.org/ or write a custom one, and monitor that. I would setup notifications based upon that, and then those hosts could depend on the Gateway VPN check status.
chandasandeep
Hi Thank you for help.
other than gateway plugin, can we monitor by host dependency. if A host is one network and B host is another network. if host B network disconnect i will get a host unreachable alert rather than down alert. why because when i checked B host manually its up and running fine.
Thanks in advance.
Sandeep
If I understand correctly, yes, you should be able to, take a look at this link - https://assets.nagios.com/downloads/nag ... ncies.html
