Hello!
I want to ask you about the check_mssql_health plug in. The plug in works properly in the server in any mode but this does not happen in Nagios web version. Could you help me with this please?
Error: UNKNOWN - cannot create status dir /var/tmp/check_mssql_health! check your filesystem (permissions/usage/integrity) and disk devices, cannot write status file /var/tmp/check_mssql_health/cpu-busy_secs_busy_ip-server
Error with nagios plugin check_mssql_health
avandemore
Re: Error with nagios plugin check_mssql_health
What XI version, OS, and OS version are you using?
Can you show your service and command definition?
Previous Nagios employee
Hi!! thanks for you response
My server nagios is a "Nagios 3.5.1", the server OS is a centos 6.3.
the service and command is:
host_name DB
service_description SQL CPU
check_command check_mssql_health!ip-server!userdb!IpasswordDB!cpu-busy
command_name check_mssql_health
command_line $USER1$/check_mssql_health --server=$ARG1$ --username=$ARG2$ --password=$ARG3$ --mode=$ARG4$
This picture shows the plugin in server and the nagios web others mode!!!!
host_name DB
- Former Nagios Staff
Can you send a screenshot of your login page? I think you are using Core, not XI.
For the moment though, let's assume you are using XI.
Can you PM me your Profile? You can download it by going to Admin > System Config > System Profile and click the Download Profile (not Show Profile) button in the top right corner. If for whatever reason you cannot download the profile, please put the output of Show Profile in the thread (that will at least get us some info).
nietonoshana
Hello
I guess your mistake is to test the command with the root user before generating it in nagios
The nagios user should not have the permissions to be able to write to the file, you can delete the directory
/var/tmp/check_mssql_health and force the immediate check to view result
What @nietonoshana said as far as the root user is correct, whether XI or Core.
If you are using core, you might want to think about upgrading. The current version is 4.2.3, but 4.2.4 should be coming out very soon.
