Adding a MIB then using it to pick checks
chrisbooth
Post by chrisbooth »
I'm trying to add a generic UPS-MIB which works in my MIB-Browser app.
the mib format looks like this:
http://pastebin.com/znsYXVAs
the mib is called UPS-MIB.mib
when i upload to nagiosxi
UPS-MIB UPS-MIB.mib apache apache rw-rw-r-- 2016-12-05 15:51:31
but i'm not sure how i can get it use that mib in the SNMP Walk wizard.
is the format of the mib incorrect?
chrisbooth
Re: Adding a MIB then using it to pick checks
i've now copied the mib into /usr/share/snmp/mibs
here's the error i get when i try to run
http://pastebin.com/vnTVDi6C
avandemore
Post by avandemore »
How did you install this MIB? Did you use https://support.nagios.com/kb/article.php?id=73 ?
Previous Nagios employee
