Hi Team,
We are migrate nagios server to our other host and after migration we are getting error please find bellow the picture
Please revert as soon as possible you can
ERROR :- SQL: SQL Error [ndoutils] : Table './nagios/nagios_servicestatus' is marked as crashed and should be repaired SQL: SQL Error [ndoutils] : Table './nagios/nagios_servicestatus' is marked as crashed and should be repaired SQL: SQL Error [ndoutils] : Table './nagios/nagios_servicestatus' is marked as crashed and should be repaired SQL: SQL Error [ndoutils] : Table './nagios/nagios_servicestatus' is marked as crashed and should be repaired SQL: SQL Error [ndoutils] : Table './nagios/nagios_servicestatus' is marked as crashed and should be repaired SQL: SQL Error [ndoutils] : Table './nagios/nagios_servicestatus' is marked as crashed and should be repaired SQL: SQL Error [ndoutils] : Table './nagios/nagios_servicestatus' is marked as crashed and should be repaired
SQL Crash,
SQL Crash,
- Former Nagios Staff
Re: SQL Crash,
Please run the following commands
*If* that does not fix the issue, please run through the following:
There are additional steps you can take at https://support.nagios.com/kb/article.php?id=24.
If you run through that document and are still having issues can you PM me your Profile? You can download it by going to Admin > System Config > System Profile and click the Download Profile (not Show Profile) button in the top right corner. If for whatever reason you cannot download the profile, please put the output of Show Profile in the thread (that will at least get us some info).
cd /usr/local/nagiosxi/scripts/
./repair_databases.sh
service mysqld stop
cd /var/lib/mysql/nagios
myisamchk -r -f nagios_<corrupted_table>
service mysqld start
rm -f /usr/local/nagiosxi/var/dbmaint.lock
php /usr/local/nagiosxi/cron/dbmaint.ph
Re: SQL Crash,
its working but its showing wrong time in server and also send alert with back time and we have change the time of nagios server and restart the sql service now its looks good,
Thakns
Thakns
Re: SQL Crash,
Are we ready to lock it up? Thanks!ivp2015 wrote: now its looks good,
