How to monitor particular process in Nagios instance?
Already process showing on process table.
please explain to me step by step solution.
Kishor Gaikwad
kishorgaikwad
- Former Nagios Staff
Re: How to monitor particular process in Nagios instance?
We're going to need a little more information. What is the process you are trying to monitor?
If the process is on Windows, then https://assets.nagios.com/downloads/nag ... ndows.html should help.
If the process is on Linux, then https://assets.nagios.com/downloads/nag ... linux.html should help. This document should also work for UNIX, but compiling agents and such on UNIX will very depending on which UNIX.
Once you get us more info we can be more specific.
Are you getting any error messages now? Any screenshots or command line output of errors would be useful. Thanks!
