I have added a switch to Nagios. To start with the port setting on a particular port was set in Kbit instead of Mbit.
After changing this I still have a very large spike saying that the load on the line was 14000Mbit (this was tested in the time the graph still showed Kbit)...
I want to delete the performance data for this particular service (port) on this switch. I do NOT want to delete the entire switch!
I have tried deleting the bandwidth/status services for this port and deleting the .rrd and .xml files under services. After that I re-added the port.
But alas: it still shows the incorrect historical data!
Can someone help me delete the performance data for just this service/port?
Delete performance data for one service.
Re: Delete performance data for one service.
The interface should have it's own RRD + XML file in a directory similar to /usr/local/nagios/share/perfdata/192.168.5.41/Port_10_Bandwidth.rrd /usr/local/nagios/share/perfdata/192.168.5.41/Port_10_Bandwidth.xml
Replace 192.168.5.41 with the proper IP of the switch, and Port_10_Bandwidth with the service name for that interface.
Once you clear this out, it'll regenerate itself once mrtg runs through and creates data points.
