Configuring nagiosxi to https redirect only
yunushaikh
Post by yunushaikh »
Hello Experts,
I have recently installed nagios xi enterprise.
I have default configuration as of now.
We have done the setting from AWS side and configured the ssl certificate from AWS itself.
Now if I open the nagios URL with http and https it works fine with both.
Requirement is now whenever there is any http request we want it directly to route to https.
Can anyone please help with what configurations needs to be done in nagios for redirecting the nagios url permanently to https even if http request is made.
Thanks a lot
eloyd
Cool Title Here
Re: Configuring nagiosxi to https redirect only
Post by eloyd »
Assuming you have a working SSL (https) configuration (if not, then read this: https://assets.nagios.com/downloads/nag ... s%20XI.pdf) then the only thing you need to do is at the Apache level, redirect all non-SSL traffic to the SSL version.
Edit /etc/httpd/conf.d/ssl.conf and add these lines at the bottom to redirect http to https:
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteRule (.*) https://%{SERVER_NAME}/%$1 [R,L]
Now, all requests to http://<server>/nagiosxi/... will be redirected to https://<server>/nagiosxi/...
Post by dwhitfield »
Thanks @eloyd!
Are we ready to lock this up?
yunushaikh
Hey Thanks for suggestion.
You can close this thread
