I've a clone of my production environment that I was using for some test and I realized that when I reboot the server Nagios don't work properly. The website loads fine and I can see on the "System Status" and "Monitoring Engine Status" all Ok in green but the checks are not being updated. If I go to "System profile" In the "Nagios XI Data" section It says that the total number of host and services are both 0 even tough I can see all my host if Ido a search or all the section of HOME like Quick view or Details.
I can solve the issue just by doing a "service nagios stop" and "service nagios start" but I'll like to figure out the reason why this is happening. The only possible reason I can see in the logs is the following two lines that are repeated constantly:
If that doesn't work for you, can you PM me your Profile? You can download it by going to Admin > System Config > System Profile and click the Download Profile (not Show Profile) button in the top right corner. If for whatever reason you cannot download the profile, please put the output of Show Profile in the thread (that will at least get us some info).
Hi, PM send with the profile attached.
I have an old installation where nagiosxi database is still on postgresql in the localhost so I can't check it with that command but the other two for nagios and nagiosql works fine. Is there an equivalent command for pgsql I can use? I've never used pgsql before by tried to get the privileges with the following commands.
nagiosxi=> \du
List of roles
Role name | Attributes | Member of
nagiosxi | | {}
postgres | Superuser | {}
: Create role
: Create DB
What error are you getting? My understanding (based on https://assets.nagios.com/downloads/nag ... OUtils.pdf) is that currently MySQL is only supported with NOutils. Furthermore, both of those errors specifically mention MySQL. I just want to make sure I am tackling the right problem. Thanks!
dwhitfield wrote:What error are you getting? My understanding (based on https://assets.nagios.com/downloads/nag ... OUtils.pdf) is that currently MySQL is only supported with NOutils. Furthermore, both of those errors specifically mention MySQL. I just want to make sure I am tackling the right problem. Thanks!
I think that mysql error I saw before was just temporal like something that hadn't start yet or something because I can't see them anymore. I tried to reboot again the whole server and still the same as expected.
I can't see any strange error on the logs but as I said,in the System profile" In the "Nagios XI Data" section It says that the total number of host and services are both 0. Also, a lot of the host stay forever in grey with the status "Service Check is pending...." and "Host Check is pending..." in case of the Host
I do have NDOUtils installed and pointing to my mysql DB. I do have a mix set up of nagiosxi database running on postgresql and NDOUtils and nagiosql databases on mysql. As I said, I can my system work if I do a service nagios restart after the reboot but I don't know why I have to do that service restart.
service nagios status
chkconfig --list |grep "ndo\|nagios"
Yes, Nagios and all the other nagios related services are running after a reboot and if I do a tail -f /usr/local/nagios/var/nagios.log I can see some checks being executed. If I look for one of the servers that are executing a check according to the nagios.log I can see it being updated as shown here where it was updated a minute ago.
But then If I access it It says like in all of them "Service Check is pending"
And also a "You are not authorized to access this feature." If I go to the Performance Graph section on that check
Also, are you seeing anything in /var/log/messages or in the dmesg command output around the time of reboot that could be related?
PM send.
I don't see any strange error or anything. The most strange thing I can see in messages is the following error but it seems to solve itself after 15 seconds or so and afterwards the first checks starts to show up in the log.
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod: NDOMOD 2.0.0 (02-28-2014) Copyright (c) 2009 Nagios Core Development Team and Community Contributors
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod: Could not open data sink! I'll keep trying, but some output may get lost...
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for process data
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for log data'
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for system command data'
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for event handler data'
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for notification data'
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for comment data'
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for downtime data'
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for flapping data'
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for program status data'
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for host status data'
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for service status data'
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for adaptive program data'
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for adaptive host data'
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for adaptive service data'
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for external command data'
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for aggregated status data'
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for retention data'
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for contact data'
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for contact notification data'
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for acknowledgement data'
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for state change data'
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for contact status data'
Dec 14 08:15:59 ESBARLMONAPP05 nagios: ndomod registered for adaptive contact data'
Dec 14 08:15:59 ESBARLMONAPP05 nagios: Event broker module '/usr/local/nagios/bin/ndomod.o' initialized successfully.
Dec 14 08:16:03 ESBARLMONAPP05 nagios: Successfully launched command file worker with pid 2534
Dec 14 08:16:03 ESBARLMONAPP05 nagios: HOST DOWNTIME ALERT: ESBARVAPP;STARTED; Host has entered a period of scheduled downtime
Dec 14 08:16:03 ESBARLMONAPP05 nagios: HOST DOWNTIME ALERT: ESBARLLOG02;STARTED; Host has entered a period of scheduled downtime
Dec 14 08:16:03 ESBARLMONAPP05 nagios: SERVICE DOWNTIME ALERT: ESBARLHANA03;Disk state;STARTED; Service has entered a period of scheduled downtime
Dec 14 08:16:03 ESBARLMONAPP05 nagios: HOST DOWNTIME ALERT: ESBARLCPOC01;STARTED; Host has entered a period of scheduled downtime
Dec 14 08:16:03 ESBARLMONAPP05 nagios: HOST DOWNTIME ALERT: ESBARLCPOC02;STARTED; Host has entered a period of scheduled downtime
Dec 14 08:16:03 ESBARLMONAPP05 nagios: SERVICE DOWNTIME ALERT: ESBARLHANA01;Disk state;STARTED; Service has entered a period of scheduled downtime
Dec 14 08:16:03 ESBARLMONAPP05 nagios: HOST DOWNTIME ALERT: ESBARLCPOC03;STARTED; Host has entered a period of scheduled downtime
Dec 14 08:16:03 ESBARLMONAPP05 nagios: SERVICE DOWNTIME ALERT: ESBARLXAPP05;/var Disk Usage;STARTED; Service has entered a period of scheduled downtime
Dec 14 08:16:03 ESBARLMONAPP05 nagios: SERVICE DOWNTIME ALERT: ESBARLHANA05;Disk state;STARTED; Service has entered a period of scheduled downtime
Dec 14 08:16:03 ESBARLMONAPP05 nagios: HOST DOWNTIME ALERT: ESBARLXAPP05;STARTED; Host has entered a period of scheduled downtime
Dec 14 08:16:03 ESBARLMONAPP05 nagios: SERVICE DOWNTIME ALERT: ESBARLXAPP02;/var Disk Usage;STARTED; Service has entered a period of scheduled downtime
Dec 14 08:16:03 ESBARLMONAPP05 nagios: HOST DOWNTIME ALERT: CNPEKWPRN01;STARTED; Host has entered a period of scheduled downtime
Dec 14 08:16:03 ESBARLMONAPP05 nagios: HOST DOWNTIME ALERT: ESBARWTXTTEMP01;STARTED; Host has entered a period of scheduled downtime
Dec 14 08:16:08 ESBARLMONAPP05 nagios: SERVICE ALERT: TMS02;SQL compilations;WARNING;SOFT;1;WARNING - 1.45 initial compilations / sec
Dec 14 08:16:15 ESBARLMONAPP05 nagios: ndomod: Successfully connected to data sink. 24658 items lost, 5000 queued items to flush.
Dec 14 08:16:15 ESBARLMONAPP05 nagios: ndomod: Successfully flushed 5000 queued items to data sink.
