graph in bytes, want it in megabytes
chrisbooth
Post by chrisbooth »
root@localhost(/usr/local/nagios/libexec):./check_qlogic_sanbox_port -H 10.101.0.13 -C public -t speed -w 500 -c 900
OK - Port is up, Partner WWPN is 24010001555CDD38 | tx_speed_bytes=89299939804c;;;; rx_speed_bytes=9949999090c;;;;
i have this command which graphs like this
can i adjust this to MByte within NagiosXI or do i need to do something with the output of the check?
Re: graph in bytes, want it in megabytes
Post by dwhitfield »
What is check_qlogic_sanbox_port? I couldn't find anything referencing it online.
Also, can you PM me your Profile? You can download it by going to Admin > System Config > System Profile and click the Download Profile button towards the top. If for whatever reason you *cannot* download the profile, please put the output of Show Profile in the thread (that will at least get us some info).
UPDATE: Profile received and shared with techs.
chrisbooth
Reason: removing profile for security purposes
I don't see any option in that plugin to change the units, but you might have a better luck contacting the developer of that plugin.
That means you'll have to modify things yourself. This post discusses modifying highcharts https://support.nagios.com/forum/viewto ... =6&t=30799 - begin with the post from 'lgroschen' and review the link to the highcharts page. This should be a good starting point, so let us know if you have any questions after checking it out - thanks.
It's entirely up to what the plugin outputs since the performance data is what builds those graphs...so you could modify things after on either end really.
chrisbooth
unfortunately i dont have access to that forum thread.
i'm happy with the data coming in as bytes.
it's more the cosmetics of the graph i'd like to change
i dont want the Y axis to show 800000 instead show 8mbs for example
The plugin developers email is [email protected].
Alternatively, you could convert in your language of choice. I suspect JS (or at least client-side JS) is not the most performant way to do this, but it might be the easiest: https://stackoverflow.com/questions/159 ... javascript
