"CHECK_NRPE: Error - Could not complete SSL handshake" error
RIDS_I2MP
Post by RIDS_I2MP »
Hi Team,
We are trying to monitor a Linux server, we have installed nrpe on it. I am receiving below error when I am executing the below command from nagios server:
[nagios@hostname libexec]$ ./check_nrpe -H <remotehost IP> -p 5666
CHECK_NRPE: Error - Could not complete SSL handshake.
[nagios@hostname libexec]$ ./check_nrpe -H <remotehost IP> -p 5666 -c check_disk -a '-w 10% -c 15% -p /opt'
But the same command is executed successfully when executed locally on the remote host:
[root@remotehost libexec]# ./check_disk -w 15% -c 10% -p /opt
DISK OK - free space: / 13772 MB (32% inode=97%);| /=28809MB;38131;40374;0;44860
We have made the nagios server IP entry in /etc/xinetd.d/nrpe file.
Kindly let us know the solution.
Reason: Please use code tags for output.
Thanks & Regards,
I2MP Team.
eloyd
Cool Title Here
Re: "CHECK_NRPE: Error - Could not complete SSL handshake" e
Post by eloyd »
Did you restart the xinetd service?
avandemore
Post by avandemore »
Please see the troubleshooting section here:
https://assets.nagios.com/downloads/nag ... e/NRPE.pdf
If that doesn't help, please post the debug log from the remote system.
Previous Nagios employee
