I have imported all my Nagios xi services on to another Nagios xi instance, but I found not all services were imported into the new Nagios.
Is there a log file that shows what activity was completed during the import?
Best Regards,
Peter
log file generated import config file
Re: log file generated import config file
If you're following this guide:
The Import Config Files tool should tell you via a big red error box if anything wasn't able to be imported correctly. Have you verified the missing object definitions are present in the files provided to the Import Config Files tool?
