issues adding guests in VMware Virtualization Wizard
jlmoldan
Post by jlmoldan »
I've successfully added the vcenter server, and am monitoring all my ESX hosts using VMware vMA Settings Manager (Version: 2015-12-19 Date: 2015-12-19 Author: Troy Lea, Nagios Enterprises, LLC ) and VMware Virtualization Wizard Version: 2014-10-23, Date: 2014-10-23, Author: Troy Lea, Nagios Enterprises, LLC
However, when I try to add a guest using the wizard it comes up with
vMA Component Not Installed OR you have not yet added any vMA Hosts OR any VMware Servers
I'm confused. It seems like if I manually create the host/service checks it works - but I'm not sure that I'm getting all the syntax right/that is a painful process. Any idea what that error means?
avandemore
Re: issues adding guests in VMware Virtualization Wizard
Post by avandemore »
Can you send a screenshot of the component Edit Settings > VMware vMA Settings Manager page?
Previous Nagios employee
jlmoldan
Post by jlmoldan »
This what you asking for? thx.
avandemore
Yes that is what I was looking for. Can you also send a screenshot showing the error:
jlmoldan
Post by jlmoldan »
Here that is
avandemore
I have notified the author of this issue and thread as we don't have anything internally to test against. Please respond back here if you don't hear back from the author within 1 business day.
Post by Box293 »
Seeing as you are able to add hosts I suspect there is a bug in the box293_check_vmware plugin.
Can you send an email to [email protected] and I will respond with a beta version of the plugin that may resolve the issue along with some other troubleshooting steps.
