Increase NRPE Buffer Size
optionstechnology
Post by optionstechnology »
nagiosXI 5.3.2
Centos 7.2
I use the following commands to increase the nrpe buffer size-
echo "use nagios;alter table nagios_servicestatus modify output varchar(65535) not null;alter table nagios_servicestatus modify long_output varchar(65535) not null;alter table nagios_servicestatus modify perfdata varchar(65535) not null;" | mysql -pnagiosxi
echo "use nagios;alter table nagios_hoststatus modify output varchar(65535) not null;alter table nagios_servicestatus modify long_output varchar(65535) not null;alter table nagios_servicestatus modify perfdata varchar(65535) not null;" | mysql -pnagiosxi
echo "use nagios;alter table nagios_servicechecks modify output varchar(65535) not null;alter table nagios_servicestatus modify long_output varchar(65535) not null;alter table nagios_servicestatus modify perfdata varchar(65535) not null;" | mysql -pnagiosxi
echo "use nagios;alter table nagios_hostchecks modify output varchar(65535) not null;alter table nagios_servicestatus modify long_output varchar(65535) not null;alter table nagios_servicestatus modify perfdata varchar(65535) not null;" | mysql -pnagiosxi
However, I am now operating on a nagiosxi instance that stores the database on a seperate server- and when I try those commands I get 'Access Denied' even while using the root account.
I have a login to MariaDB but obviously the syntax of those commands above need to be changed...
Can you guys help?
Re: Increase NRPE Buffer Size
Post by mcapra »
We do not support direct manipulation of the Nagios XI database. As a warning, altering tables that Nagios XI relies on can make your system un-supported in some cases.
Assuming the passwords are the same on the offloaded database, you will need to add the -h argument to your mysql call to include the remote server's hostname.
 -h, --host=name     Connect to host.
You may also need to alter the credentials provided if the root password was changed.
optionstechnology
This can be closed
Post by dwhitfield »
I am going to lock the thread. Please feel free to post again if you have you another issue. Thank you for using the Nagios forums!
