Hello everyone
Can anyone help me with the update of nagios on Fedora and Epel repository?
I have installed manually on Fedora25 an old version but there is a mistake with the socket and selinux.
Please, I would appreciate someone include the fix in the package creating inluding this script like postinstall.
---The fix is---
#cat > /tmp/nagios-socket.te <<BEG
module nagios-socket 1.0;
require {
type nagios_t;
type nagios_log_t;
class sock_file { write create unlink };
class unix_stream_socket connectto;
allow nagios_t nagios_log_t:sock_file { write create unlink };
allow nagios_t self:unix_stream_socket connectto;
BEG
yum install policycoreutils-python -y
cd /tmp;checkmodule -M -m -o nagios-socket.mod nagios-socket.te
semodule_package -o nagios-socket.pp -m nagios-socket.mod
semodule -i nagios-socket.pp
install -d -m 755 -o nagios -g nagios /var/log/nagios/rw
systemctl restart nagios && systemctl status nagios
Greetings from Colombia
Thank you
Update Nagios on epel and fedora please
joseluismantilla
Re: Update Nagios on epel and fedora please
If you're referring to providing a fix to the nagios package included in the Fedora repositories, we do not have control over that package. You'd be best off contacting the individual responsible for maintaining that package:
https://apps.fedoraproject.org/packages/nagios
