Hi;
Wanted to check if there is a way to modify the bb map view in nagios xi to show the non-green checks.
-Krishna
Nagios filter bb map view
Re: Nagios filter bb map view
Please explain in detail what you are trying to do as I'm having trouble understanding what exactly you're looking for, the BBMap shows the problem state hosts and services already, are you trying to hide the OK ones?
yes, That is correct. I want to show only the CRITICAL ones and hide the OK checks.
-Krishna
-Krishna
Currently this isn't going to be possible, but I filed a FR so it may make it into a future release. The ID is #10506
