MSSQL
orani
MSSQL
Post by orani »
i am using the wizards for MSSQL that nagios have and i am getting the follown error
(No output on stdout) stderr: /bin/sh: -c: line 0: unexpected EOF while looking for matching `''
any ideas what is happening?
ruffsense
Re: MSSQL
Post by ruffsense »
with all the checks?
I don't insult, I diagnose.
Re: MSSQL
Post by dwhitfield »
Can you post a screenshot of the check you are using (of the command line if you are running from command line)? It looks to me like you are missing a closing quote.
Also, what version of XI are you running and what version of MSSQL?
orani
Re: MSSQL
Post by orani »
@ruffsense yes at all checks
@dwhitfield i used the MSSQL wizard for database monitoring and i just filled the username and password. i run the latest version of nagios xi and MSSQL 2012 v. 11.0.5058.0
orani
Re: MSSQL
Post by orani »
Thats my screenshots. if you need extra infos please let me know
Re: MSSQL
Also see a 20009 error. If you want to take that, run the following:
    export TDSDUMP=/tmp/freetds.log
    tsql -H myip -p 1433 -U myuser
(replace myip / myuser as needed, and enter the SQL Server password when prompted)
As for the missing ", can you PM me your Profile? You can download it by going to Admin > System Config > System Profile and click the Download Profile button towards the top. If for whatever reason you *cannot* download the profile, please put the output of View System Info (5.3.4+, Show Profile if older) in the thread (that will at least get us some info).
