How to monitor Docker containers with Nagios
naveen46
Post by naveen46 »
I need help in Monitoring Docker containers with Nagios.
Re: How to monitor Docker containers with Nagios
Post by dwhitfield »
You'll want to check out https://exchange.nagios.com/directory/P ... er/details if you haven't already.
To help us help you: What version of Core are you using? Was it compiled from source or installed from distro repos? On what OS/version is nagios running? cat /etc/*-release may be of use. Also, please give us as much info as you can about what you are trying to monitor in docker...like, what applications and metrics? Thanks!
naveen46
Post by naveen46 »
I am using CentOS release 6.6 (Final) OS, Nagios core Version is 4.2.0.
You neglected to give us any information about what you are trying to monitor in docker. If you are running enough of the OS in docker, you should be able to monitor them just like any other OS, but we will need more information if we are going to be more specific.
Did you look at the plugin I suggested?
Also, I will note that 4.2.4 fixes a serious security hole, so you might want to look at upgrading: https://assets.nagios.com/downloads/nag ... ading.html
naveen46
Post by naveen46 »
Yes, I tried to use that plugin getting error like NRPE: Unable to read output.
NRPE 3.0, Nagios-plugins -2.1.4
avandemore
Post by avandemore »
We have a NRPE troubleshooting document: https://assets.nagios.com/downloads/nag ... utions.pdf
It says it's for XI, but it's applicable to Core as well.
Previous Nagios employee
In addition to the trouble-shooting document, are you running NRPE through xinetd or stand-alone? If the second, did you allow it through the firewall? Did you add the server's IP into your allowed_from in your nrpe.cfg?
Also, can you upload as a file your /usr/local/nagios/var/objects.cache? Thanks!
naveen46
Post by naveen46 »
running through xinetd service, Yes I've added server's IP into nrpe.cfg file.
objects.cache.txt
(24.94 KiB) Downloaded 435 times
Post by mcapra »
If NRPE is running under xinetd, you will need to alter a different file to whitelist the Nagios XI machine. The file you want to be altering is usually located at /etc/xinetd.d/nrpe. Specifically, the only_from directive. You will also need to restart the xinetd service after changing this file.
naveen46
Post by naveen46 »
there is no NRPE file in /etc/xinetd.d/ location
