Hi Guys
so you guys have a little background information i have nagios up and running on a fedora VM this is working fine its monitoring the local host sending emails took a bit of head scratching but i got there in the end.
my problem now lies with configuring several 3rd party scripts mainly Python and VBS. i am monitoring several widows servers using the NSclient ++ which is working fine untill i try and use one of the scripts they just dont behave as i would expect. this is the script im currently trying to configure http://exchange.nagios.org/directory/Pl ... ck/details but maybe there is a better alternative.
my questions are
is NSClient ++ the best tool to use i have seen NRPE mentioned but im not really too sure what it is or how i got about setting it up but my understanding it will allow me to run scripts remotely.
my enviroment is mainly windows checking services are running, HTTP, FTP etc are working fine with the NScleint++, what im trying to do is monitor a folder for new files and if they become x minutes old to create a warning and then a critical
ideally i would like to monitor all services etc and be able to run scripts and eventually get to the point were i can run a script in the event of a critical issue for example restart a service.
any help would be greatly appreciated on the best route to take
cheers
Several Questions from a Noob
Re: Several Questions from a Noob
To answer your first question, NSClient++ is definitely the best windows client... NRPE to put it simply is a form of communication that Nagios can use; NSClient uses NRPE as one of its main communication methods.
I think you are on the right track, can you do the following:
-Attempt to run the script on the windows command line, does it give you the return you expect?
-Can you post your Nagios service configuration for this check and can you post your definition in NSC.ini?
HI really appreciate the responce was starting tho loose hope
the command works as expected from the wondows client i had to install python but other than that calling the script from the command line works as expected
this is the line from my commands.cfg
this is my NSC.ini nothing has really been changed in here from the initial install
will NRPE be configured by default within nagios ?
kind regards
##Check File Age
command_name check_fileage
command_line $USER1$/check_fileage.py -f "//10.110.201.74/Mr t" -w 10 -c 50
}Code: Select all
[modules]
;# NSCLIENT++ MODULES
;# A list with DLLs to load at startup.
; You will need to enable some of these for NSClient++ to work.
; * N O T I C E ! ! ! - Y O U H A V E T O E D I T T H I S *
FileLogger.dll
CheckSystem.dll
CheckDisk.dll
NSClientListener.dll
NRPEListener.dll
SysTray.dll
CheckEventLog.dll
CheckHelpers.dll
;CheckWMI.dll
CheckNSCP.dll
; Script to check external scripts and/or internal aliases.
CheckExternalScripts.dll
; NSCA Agent if you enable this NSClient++ will talk to NSCA hosts repeatedly (so dont enable unless you want to use NSCA)
;NSCAAgent.dll
; LUA script module used to write your own "check deamon".
;LUAScript.dll
; RemoteConfiguration IS AN EXTREM EARLY IDEA SO DONT USE FOR PRODUCTION ENVIROMNEMTS!
;RemoteConfiguration.dll
; Check other hosts through NRPE extreme beta and probably a bit dangerous! :)
;NRPEClient.dll
; Extreamly early beta of a task-schedule checker
;CheckTaskSched.dll
[crash]
; Archive crash dump files if a crash is detected
;archive=1
; Submit crash reports to a crash report server (this overrrides archive)
;submit=0
; Restart service if a crash is detected
;restart=1
[Settings]
;# OBFUSCATED PASSWORD
; This is the same as the password option but here you can store the password in an obfuscated manner.
; *NOTICE* obfuscation is *NOT* the same as encryption, someone with access to this file can still figure out the
; password. Its just a bit harder to do it at first glance.
;obfuscated_password=Jw0KAUUdXlAAUwASDAAB
;# PASSWORD
; This is the password (-s) that is required to access NSClient remotely. If you leave this blank everyone will be able to access the daemon remotly.
;password=#R3m0te#
;# ALLOWED HOST ADDRESSES
; This is a comma-delimited list of IP address of hosts that are allowed to talk to the all daemons.
; If leave this blank anyone can access the deamon remotly (NSClient still requires a valid password).
; The syntax is host or ip/mask so 192.168.0.0/24 will allow anyone on that subnet access
;allowed_hosts=10.110.201.44/32
;# USE THIS FILE
; Use the INI file as opposed to the registry if this is 0 and the use_reg in the registry is set to 1
; the registry will be used instead.
use_file=1
;password=#R3m0te#
; # USE SHARED MEMORY CHANNELS
; This is the "new" way for using the system tray based on an IPC framework on top shared memmory channels and events.
; It is brand new and (probably has bugs) so dont enable this unless for testing!
; If set to 1 shared channels will be created and system tray icons created and such and such...
;shared_session=0
[log]
;# LOG DEBUG
; Set to 1 if you want debug message printed in the log file (debug messages are always printed to stdout when run with -test)
;debug=1
;# LOG FILE
; The file to print log statements to
;file=nsclient.log
;# LOG DATE MASK
; The format to for the date/time part of the log entry written to file.
;date_mask=%Y-%m-%d %H:%M:%S
;# LOG ROOT FOLDER
; The root folder to use for logging.
; exe = the folder where the executable is located
; local-app-data = local application data (probably a better choice then the old default)
;root_folder=exe
[NSClient]
; This is a comma-delimited list of IP address of hosts that are allowed to talk to NSClient deamon.
; If you leave this blank the global version will be used instead.
;allowed_hosts=
;# NSCLIENT PORT NUMBER
; This is the port the NSClientListener.dll will listen to.
port=12489
;# BIND TO ADDRESS
; Allows you to bind server to a specific local address. This has to be a dotted ip adress not a hostname.
; Leaving this blank will bind to all avalible IP adresses.
;bind_to_address=
;# SOCKET TIMEOUT
; Timeout when reading packets on incoming sockets. If the data has not arrived withint this time we will bail out.
;socket_timeout=30
[NRPE]
;# NRPE PORT NUMBER
; This is the port the NRPEListener.dll will listen to.
;port=5666
;# COMMAND TIMEOUT
; This specifies the maximum number of seconds that the NRPE daemon will allow plug-ins to finish executing before killing them off.
;command_timeout=60
;# COMMAND ARGUMENT PROCESSING
; This option determines whether or not the NRPE daemon will allow clients to specify arguments to commands that are executed.
;allow_arguments=0
;# COMMAND ALLOW NASTY META CHARS
; This option determines whether or not the NRPE daemon will allow clients to specify nasty (as in |`&><'"\[]{}) characters in arguments.
;allow_nasty_meta_chars=0
;# USE SSL SOCKET
; This option controls if SSL should be used on the socket.
;use_ssl=1
;# BIND TO ADDRESS
; bind_to_address=
; This is a comma-delimited list of IP address of hosts that are allowed to talk to NRPE deamon.
;allowed_hosts=
;# SCRIPT DIRECTORY
; All files in this directory will become check commands.
; *WARNING* This is undoubtedly dangerous so use with care!
;script_dir=scripts\
;# SOCKET TIMEOUT
;socket_timeout=30
[Check System]
;# CPU BUFFER SIZE
; Can be anything ranging from 1s (for 1 second) to 10w for 10 weeks. Notice that a larger buffer will waste memory
; so don't use a larger buffer then you need (ie. the longest check you do +1).
;CPUBufferSize=1h
;# CHECK RESOLUTION
; The resolution to check values (currently only CPU).
; The value is entered in 1/10:th of a second and the default is 10 (which means ones every second)
;CheckResolution=10
;# CHECK ALL SERVICES
; Configure how to check services when a CheckAll is performed.
; ...=started means services in that class *has* to be running.
; ...=stopped means services in that class has to be stopped.
; ...=ignored means services in this class will be ignored.
;check_all_services[SERVICE_BOOT_START]=ignored
;check_all_services[SERVICE_SYSTEM_START]=ignored
;check_all_services[SERVICE_AUTO_START]=started
;check_all_services[SERVICE_DEMAND_START]=ignored
;check_all_services[SERVICE_DISABLED]=stopped
[External Script]
;# COMMAND TIMEOUT
;command_timeout=60
;allow_arguments=0
;# SCRIPT DIRECTORY
;script_dir=c:\my\script\dir
[Script Wrappings]
vbs=cscript.exe //T:30 //NoLogo scripts\lib\wrapper.vbs %SCRIPT% %ARGS%
ps1=cmd /c echo scripts\%SCRIPT% %ARGS%; exit($lastexitcode) | powershell.exe -command -
bat=scripts\%SCRIPT% %ARGS%
[External Scripts]
;check_es_long=scripts\long.bat
;check_es_ok=scripts\ok.bat
;check_es_nok=scripts\nok.bat
;check_vbs_sample=cscript.exe //T:30 //NoLogo scripts\check_vb.vbs
;check_powershell_warn=cmd /c echo scripts\powershell.ps1 | powershell.exe -command -
[External Alias]
alias_cpu=checkCPU warn=80 crit=90 time=5m time=1m time=30s
alias_cpu_ex=checkCPU warn=$ARG1$ crit=$ARG2$ time=5m time=1m time=30s
alias_mem=checkMem MaxWarn=80% MaxCrit=90% ShowAll=long type=physical type=virtual type=paged type=page
alias_up=checkUpTime MinWarn=1d MinWarn=1h
alias_disk=CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED
alias_disk_loose=CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED ignore-unreadable
alias_volumes=CheckDriveSize MinWarn=10% MinCrit=5% CheckAll=volumes FilterType=FIXED
alias_volumes_loose=CheckDriveSize MinWarn=10% MinCrit=5% CheckAll=volumes FilterType=FIXED ignore-unreadable
alias_service=checkServiceState CheckAll
alias_service_ex=checkServiceState CheckAll "exclude=Net Driver HPZ12" "exclude=Pml Driver HPZ12" exclude=stisvc
alias_process=checkProcState "$ARG1$=started"
alias_process_stopped=checkProcState "$ARG1$=stopped"
alias_process_count=checkProcState MaxWarnCount=$ARG2$ MaxCritCount=$ARG3$ "$ARG1$=started"
alias_process_hung=checkProcState MaxWarnCount=1 MaxCritCount=1 "$ARG1$=hung"
alias_event_log=CheckEventLog file=application file=system MaxWarn=1 MaxCrit=1 "filter=generated gt -2d AND severity NOT IN ('success', 'informational') AND source != 'SideBySide'" truncate=800 unique descriptions "syntax=%severity%: %source%: %message% (%count%)"
alias_file_size=CheckFiles "filter=size > $ARG2$" "path=$ARG1$" MaxWarn=1 MaxCrit=1 "syntax=%filename% %size%" max-dir-depth=10
alias_file_age=checkFile2 filter=out "file=$ARG1$" filter-written=>1d MaxWarn=1 MaxCrit=1 "syntax=%filename% %write%"
alias_sched_all=CheckTaskSched "filter=exit_code ne 0" "syntax=%title%: %exit_code%" warn=>0
alias_sched_long=CheckTaskSched "filter=status = 'running' AND most_recent_run_time < -$ARG1$" "syntax=%title% (%most_recent_run_time%)" warn=>0
alias_sched_task=CheckTaskSched "filter=title eq '$ARG1$' AND exit_code ne 0" "syntax=%title% (%most_recent_run_time%)" warn=>0
alias_updates=check_updates -warning 0 -critical 0
check_ok=CheckOK Everything is fine!
[Wrapped Scripts]
;check_test_vbs=check_test.vbs /arg1:1 /arg2:1 /variable:1
;check_test_ps1=check_test.ps1 arg1 arg2
;check_test_bat=check_test.bat arg1 arg2
;check_battery=check_battery.vbs
;check_printer=check_printer.vbs
;check_updates=check_updates.vbs
; [includes]
;# The order when used is "reversed" thus the last included file will be "first"
;# Included files can include other files (be carefull only do basic recursive checking)
; myotherfile.ini
; real.ini
[NSCA Agent]
;# CHECK INTERVALL (in seconds)
; How often we should run the checks and submit the results.
;interval=5
;# ENCRYPTION METHOD
; This option determines the method by which the send_nsca client will encrypt the packets it sends
; to the nsca daemon. The encryption method you choose will be a balance between security and
; performance, as strong encryption methods consume more processor resources.
; You should evaluate your security needs when choosing an encryption method.
; Note: The encryption method you specify here must match the decryption method the nsca daemon uses
; (as specified in the nsca.cfg file)!!
; Values:
; 0 = None (Do NOT use this option)
; 1 = Simple XOR (No security, just obfuscation, but very fast)
; 2 = DES
; 3 = 3DES (Triple DES)
; 4 = CAST-128
; 6 = xTEA
; 8 = BLOWFISH
; 9 = TWOFISH
; 11 = RC2
; 14 = RIJNDAEL-128 (AES)
; 20 = SERPENT
;encryption_method=14
;# ENCRYPTION PASSWORD
; This is the password/passphrase that should be used to encrypt the sent packets.
;password=
;# BIND TO ADDRESS
; Leaving this blank will bind to "one" local interface.
; -- not supported as of now --
;bind_to_address=
;# LOCAL HOST NAME
; The name of this host (if empty "computername" will be used.
;hostname=
;# NAGIOS SERVER ADDRESS
; The address to the nagios server to submit results to.
;nsca_host=192.168.0.1
;# NAGIOS SERVER PORT
; The port to the nagios server to submit results to.
;nsca_port=5667
;# CHECK COMMAND LIST
; The checks to run everytime we submit results back to nagios
; Any command(alias/key) starting with a host_ is sent as HOST_COMMAND others are sent as SERVICE_COMMANDS
; where the alias/key is used as service name.
[NSCA Commands]
;my_cpu_check=checkCPU warn=80 crit=90 time=20m time=10s time=4
;my_mem_check=checkMem MaxWarn=80% MaxCrit=90% ShowAll type=page
;my_svc_check=checkServiceState CheckAll exclude=wampmysqld exclude=MpfService
;host_check=check_ok
;# REMOTE NRPE PROXY COMMANDS
; A list of commands that check other hosts.
; Used by the NRPECLient module
[NRPE Client Handlers]
check_other=-H 192.168.0.1 -p 5666 -c remote_command -a arguments
;# LUA SCRIPT SECTION
; A list of all Lua scripts to load.
;[LUA Scripts]
;scripts\test.luaany help would be greatly appreciated
kind regards
I see what's happened here
You need to install the script on the machine running NSClient, not try to execute it from the Nagios server.
1. Put the script in C:\Program files\Nsclient\scripts.
2. Edit NSC.ini and go to the [External scripts] heading
3. Add an entry along the lines of: check_fileage=scripts\check_fileage.py -f "//10.110.201.74/Mr t" -w 10 -c 50
4. Your service definition should look something like:
**your normal service definition stuff here**
check_command check_nrpe!check_fileage
What you are configuring here is for Nagios to send a message via NRPE to NSclient telling it to execute the check_fileage command defined in NSC.ini. When the script finishes running it will then send that information back to Nagios. Your current configuration tells it to execute check_fileage.py on the linux box which for obvious reasons won't work.
Hi Guys
It Works
just so this topic has all the information after following the above steps i was was almost there there was just an issue with the command in NSC.ini
this is the line i had to add
check_fileage=C:\Python27\python.exe scripts\check_fileage.py -f "c:\garyddl-private.ppk" -w 10 -c 50
i had to specify the type of script in this case python
other things i had to do were configure NRPE on the nagios host using the fantastic guide below
i. Install the check_nrpe plugin
Become the root user. You may have to use sudo -s on Ubuntu and other distros.
su -l
Create a directory for storing the downloads.
mkdir ~/downloads
cd ~/downloads
Download the source code tarball of the NRPE addon (visit http://www.nagios.org/download/ for links to the latest
versions). At the time of writing, the latest version of NRPE was 2.8.
wget http://osdn.dl.sourceforge.net/sourcefo ... 2.8.tar.gz
Extract the NRPE source code tarball.
tar xzf nrpe-2.8.tar.gz
cd nrpe-2.8
Compile the NRPE addon.
./configure
make all
Install the NRPE plugin.
make install-plugin
once that was configured i could check connectivity using this command
/usr/local/nagios/libexec/check_nrpe -H 1.1.1.1
then ammending the config file for the perticular machine to include check_nrpe!check_fileage i was up and running
hopefully the above is usual to someone as ive lost a fair bit of hair over the above but now its working and i have the knowledge to configure more 3rd party scripts
cheers jsmurphy
It Works
su -l
mkdir ~/downloads
cd ~/downloads
cd nrpe-2.8
./configure
make all
make install-plugin
cheers jsmurphy
You're welcome! I forgot that NRPE wasn't part of the base Nagios package, glad you got it working.
thanks mate yeh its working well ive got a few more questions but il start some new topics to keep things tidy
