Nagios XI db queries HTLM report
Naveed
Post by Naveed »
I have multiple queries those are running on sql server.
I want to check the status of every job status failure/success.
Can nagios XI support to send us report data in tabular form.
Please guide.
Re: Nagios XI db queries HTLM report
Post by dwhitfield »
We have several MS SQL plugins at https://exchange.nagios.com/directory/P ... /SQLServer. Which, if any, have you looked at?
There is an internal feature request for custom reports (7724). There is no ETA on inclusion of the FR. I know the major feature for 5.4 will be upgrading the underlying Core. Past that, I would just be guessing.
If you set up your host groups properly, you should be able to get something you are looking for. I'm not sure if the two questions are connected. If not, it might be wise to open a new thread on the reporting aspect. If you are specifically looking for reports from MSSQL though, no need for a separate thread.
