For this I am using the below URL (NDOUtils.pdf) :
https://assets.nagios.com/downloads/nag ... OUtils.pdf
In my case MariaDB database and Nagios in on different Server.
I run the following command
yum -y install mysql-client gcc-c++ libdbi-dbd-mysql
tar xzf ndoutils-2.1.2.tar.gz
cd ndoutils-2.1.2
./configure
make allCode: Select all
[root@localhost ndoutils-2.1.2]# make all
cd ./src && make
make[1]: Entering directory `/root/nagios/ndoutils-2.1.2/src'
gcc -fPIC -fPIC -g -O2 -DHAVE_CONFIG_H -c -o io.o io.c
gcc -fPIC -g -O2 -DHAVE_CONFIG_H -o file2sock file2sock.c io.o utils.o -lm -lnsl
gcc -fPIC -g -O2 -DHAVE_CONFIG_H -o log2ndo log2ndo.c io.o utils.o -lm -lnsl
make ndo2db-2x
make[2]: Entering directory `/root/nagios/ndoutils-2.1.2/src'
gcc -fPIC -g -O2 -DHAVE_CONFIG_H -c -o db.o db.c
db.c: In function ‘ndo2db_db_init’:
db.c:169:29: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_conn’
if(!mysql_init(&idi->dbinfo.mysql_conn)){
db.c: In function ‘ndo2db_db_connect’:
db.c:211:16: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_conn’
&idi->dbinfo.mysql_conn,
db.c:218:4: error: ‘CLIENT_REMEMBER_OPTIONS’ undeclared (first use in this function)
db.c:218:4: note: each undeclared identifier is reported only once for each function it appears in
db.c:220:27: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_conn’
mysql_close(&idi->dbinfo.mysql_conn);
db.c:221:101: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_conn’
syslog(LOG_USER|LOG_INFO,"Error: Could not connect to MySQL database: %s",mysql_error(&idi->dbinfo.mysql_conn));
db.c: In function ‘ndo2db_db_disconnect’:
db.c:244:26: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_conn’
db.c: In function ‘ndo2db_db_hello’:
db.c:268:14: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_result’
idi->dbinfo.mysql_result=mysql_store_result(&idi->dbinfo.mysql_conn);
db.c:268:59: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_conn’
db.c:269:18: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_row’
if((idi->dbinfo.mysql_row=mysql_fetch_row(idi->dbinfo.mysql_result))!=NULL){
db.c:269:56: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_result’
db.c:270:53: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_row’
ndo2db_convert_string_to_unsignedlong(idi->dbinfo.mysql_row[0],&idi->dbinfo.instance_id);
db.c:273:32: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_result’
mysql_free_result(idi->dbinfo.mysql_result);
db.c:274:14: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_result’
idi->dbinfo.mysql_result=NULL;
db.c:283:56: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_conn’
idi->dbinfo.instance_id=mysql_insert_id(&idi->dbinfo.mysql_conn);
db.c:303:55: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_conn’
idi->dbinfo.conninfo_id=mysql_insert_id(&idi->dbinfo.mysql_conn);
db.c: In function ‘ndo2db_db_query’:
db.c:477:30: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_conn’
if (mysql_query(&idi->dbinfo.mysql_conn,buf)) {
db.c:479:75: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_conn’
syslog(LOG_USER|LOG_INFO,"mysql_error: '%s'\n", mysql_error(&idi->dbinfo.mysql_conn));
db.c: In function ‘ndo2db_handle_db_error’:
db.c:512:33: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_conn’
result=mysql_errno(&idi->dbinfo.mysql_conn);
db.c:513:13: error: ‘CR_SERVER_LOST’ undeclared (first use in this function)
if(result==CR_SERVER_LOST || result==CR_SERVER_GONE_ERROR){
db.c:513:39: error: ‘CR_SERVER_GONE_ERROR’ undeclared (first use in this function)
db.c: In function ‘ndo2db_db_get_latest_data_time’:
db.c:565:14: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_result’
db.c:565:59: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_conn’
db.c:566:18: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_row’
db.c:566:56: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_result’
db.c:567:53: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_row’
ndo2db_convert_string_to_unsignedlong(idi->dbinfo.mysql_row[0],t);
db.c:569:32: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_result’
db.c:570:14: error: ‘ndo2db_dbconninfo’ has no member named ‘mysql_result’
idi->dbinfo.mysql_result=NULL;I am using CentOS 7, Nagios Core 4.2.2, NDOUtils v2.1.2 and MariaDB-5.5.50.
