Ports" and followed it's instructions. I am not seeing the logs in my dashboard.
TCPDUMP on the LS shows that the packets are getting to the server. (See Below)
Any advice?
[root@localhost ~]# tcpdump -nnvvS host 10.101.2.72
tcpdump: listening on eth0, link-type EN10MB (Ethernet), capture size 65535 bytes
08:31:47.124710 IP (tos 0x0, ttl 254, id 51, offset 0, flags [none], proto UDP (17), length 133)
10.101.2.72.52001 > 10.100.10.7.514: [udp sum ok] SYSLOG, length: 105
Facility local7 (23), Severity notice (5)
Msg: 92413: Dec 28 08:31:43 EST5: %SYS-5-CONFIG_I: Configured from console by bianco on vty0 (10.75.2.13)
0x0000: 3c31 3839 3e39 3234 3133 3a20 4465 6320
0x0010: 3238 2030 383a 3331 3a34 3320 4553 5435
0x0020: 3a20 2553 5953 2d35 2d43 4f4e 4649 475f
0x0030: 493a 2043 6f6e 6669 6775 7265 6420 6672
0x0040: 6f6d 2063 6f6e 736f 6c65 2062 7920 6269
0x0050: 616e 636f 206f 6e20 7674 7930 2028 3130
0x0060: 2e37 352e 322e 3133 29
08:31:47.124756 IP (tos 0xc0, ttl 64, id 23908, offset 0, flags [none], proto ICMP (1), length 161)
10.100.10.7 > 10.101.2.72: ICMP host 10.100.10.7 unreachable - admin prohibited, length 141
