check by SSH no error message
CFT6Server
Post by CFT6Server »
I am setting up another box with check by SSH. This worked on other boxes but not this redhat box and I am not sure why.
I have confirmed that ssh with the keys worked by doing ssh nagos@remoteip, this connects no problem. When testing the nagios checks, it is coming back with a blank error message. Any ideas? Did I miss something?
# ./check_by_ssh -H remote -C uptime
Remote command execution failed:
Re: check by SSH no error message
When you ssh into the machine, are there any 'pre' text type things that show up in the terminal? In the past, I've had to add -E 1 (IIRC) to skip the initial terminal prompt.
     -S, --skip-stdout[=n]
        Ignore all or (if specified) first n lines on STDOUT [optional]
     -E, --skip-stderr[=n]
        Ignore all or (if specified) first n lines on STDERR [optional]
If that doesn't help, could you show us the full output when running ssh user@host, and also running check_by_ssh with -v? This should provide a bit more information.
CFT6Server
Perfect. Thanks! -E did the trick as there was a banner message that caused it.
ssax
Dreams In Code
Post by ssax »
That's great to hear, are we okay to lock this and mark it as resolved or do you have any other related questions?
Thank you
CFT6Server
That's it. Thanks.
