Hi Team,
We are getting below error on installing agent at SuSe12. Please help on this.
Error:
./fullinstall SUSE is not currently supported. Please use either Red Hat, CentOS, Oracle Linux, SUSE Enterprise, OpenSUSE, Ubuntu, or Debian.
Server Details:
cat /etc/SuSE-release
SUSE Linux Enterprise Server 12 (x86_64)
VERSION = 12
PATCHLEVEL = 2
# This file is deprecated and will be removed in a future service pack or release.
# Please check /etc/os-release for details about this release.
cat /etc/os-release
NAME="SLES"
VERSION="12-SP2"
VERSION_ID="12.2"
PRETTY_NAME="SUSE Linux Enterprise Server 12 SP2"
ID="sles"
ANSI_COLOR="0;32"
CPE_NAME="cpe:/o:suse:sles:12:sp2"
Regards,
Sk Abdul Goffar
Error on Agent Install for SUSE12
Regards,
Sk Abdul Goffar
Nagios Version:Nagios XI 5.4.8
OS:CentOS release 6.5
Sk Abdul Goffar
Re: Error on Agent Install for SUSE12
Take a look at the manual 'Installing from Source' instructions which may work - https://support.nagios.com/kb/article.p ... ategory=22
Depending on issues you see with NRPE 2.15, it might be worth attempting to compile NRPE 3. There are directions specifically for SUSE for NRPE 3 here - https://support.nagios.com/kb/article.p ... ategory=22
We are getting below error on installing NRPE v2.15 to below system from source. When we are running command ./configure --enable-command-args
checking for SSL headers... configure: error: Cannot find ssl headers
System Details:
NAME="SLES_SAP"
VERSION="12-SP1"
VERSION_ID="12.1.0.1"
PRETTY_NAME="SUSE Linux Enterprise Server for SAP Applications 12 SP1"
ID="sles_sap"
ANSI_COLOR="0;32"
CPE_NAME="cpe:/o:suse:sles_sap:12:sp1"
FYI: We are following the procedure mentioned in https://support.nagios.com/kb/article.p ... ategory=22.
System Details:
NAME="SLES_SAP"
VERSION="12-SP1"
ID="sles_sap"
ANSI_COLOR="0;32"
Regards,
Sk Abdul Goffar
Sk Abdul Goffar
Can you share the full URL to the article you're using? It looks like it was copy+pasted from the above post which truncates the full URL. Those instructions are specifically for NRPE v3 though. I would suggest attempting them with NRPE v3 rather than NRPE v2.15.
https://support.nagios.com/kb/article.p ... ategory=22 this is the articale
Regards,
Sk Abdul Goffar
Sk Abdul Goffar
I would suggest trying to install NRPE v3 instead of 2.15. There were some pretty big changes to encryption which may be more accommodating for your SUSE machine.
https://support.nagios.com/kb/article.php?id=515
Let us know if you encounter issues with the steps provided for installing NRPE v3.
After Installing openssl-devel package it's working fine.
Regards,
Sk Abdul Goffar
Sk Abdul Goffar
Thank you for the update. Were there any further issues or are we okay to close the thread at this point?
