update-error
bashar.abed
update-error
Post by bashar.abed »
when i checked the update issue on Nagios application Check For Updates i see this error as attached
thanks
Re: update-error
Post by dwhitfield »
Manual upgrades are generally better: https://assets.nagios.com/downloads/nag ... ctions.pdf
Please let us know if you run into any trouble with the manual upgrade...or if I am misunderstanding your problem.
bashar.abed
Re: update-error
thanks now the website is running well now
Re: update-error
Excellent! Are we ready to lock this up?
bashar.abed
Re: update-error
thanks you can close it
