I just found the other post and performed following step.
delgroup nagios
deluser nagios
rm -f /etc/xinet.d/nrpe
service xinetd restart
rm -rf /usr/local/nagiosCode: Select all
[root@bssoap11 linux-nrpe-agent]# ./fullinstall
Your system $PATH does not include /sbin and /usr/sbin. This is usually the result of installing GNOME rather than creating a clean system.
Adding /sbin and /usr/sbin to $PATH.
Nagios Linux Agent Installer
This script will install the Nagios Linux Agent by executing all necessary
sub-scripts.
IMPORTANT: This script should only be used on a clean installed system:
RedHat Enterprise, CentOS, Fedora, or Oracle
OpenSUSE or SUSE Enterprise
Ubuntu or Debian
Do NOT use this on a system running any other distro or that
does not allow additional package installation.
Do you want to continue? [Y/n] Y
Proceeding with installation...
Running './0-repos'...
Repos already configured - exiting.
RESULT=0
Running './1-prereqs'...
Prereqs already installed - skipping...
RESULT=0
Running './2-usersgroups'...
Users/groups already configured - skipping.
RESULT=0
Running './3-services'...
/etc/services already updated - skipping.
RESULT=0
Running './4-firewall'...
Firewall rules already configured - skipping.
RESULT=0
Running './A-subcomponents'...
Subcomponents already configured - skipping.
RESULT=0
### Nagios XI Linux Agent Installation Complete! ###
If you experience any problems, please attach the file install.log that was just created to any support requests.
/usr/local/nagios/libexec/check_nrpe -H 127.0.0.1
connect to address 127.0.0.1 port 5666: Connection refused
connect to host 127.0.0.1 port 5666: Connection refused
Thanks.
