nagiosxi-deps-5.2.9-1.noarch conflicts nagios-nrpe
strmon
Post by strmon »
I am trying to install nagioxi and getting below conflicts. Suggest how to resolve it?
Os: redhat 6
Nagiosxi:5.2.9
Resolving Dependencies
--> Running transaction check
---> Package nagiosxi-deps.noarch 0:5.2.9-1 will be installed
--> Processing Dependency: mysql for package: nagiosxi-deps-5.2.9-1.noarch
--> Processing Dependency: mysql-devel for package: nagiosxi-deps-5.2.9-1.noarch
--> Processing Dependency: mysql-server for package: nagiosxi-deps-5.2.9-1.noarch
--> Processing Dependency: postgresql-server for package: nagiosxi-deps-5.2.9-1.noarch
---> Package mysql.x86_64 0:5.1.73-7.el6 will be installed
---> Package mysql-devel.x86_64 0:5.1.73-7.el6 will be installed
---> Package mysql-server.x86_64 0:5.1.73-7.el6 will be installed
---> Package postgresql-server.x86_64 0:8.4.20-6.el6 will be installed
--> Processing Dependency: postgresql(x86-64) = 8.4.20-6.el6 for package: postgresql-server-8.4.20-6.el6.x86_64
---> Package postgresql.x86_64 0:8.4.20-6.el6 will be installed
--> Processing Conflict: nagiosxi-deps-5.2.9-1.noarch conflicts nagios-nrpe
No package matched to upgrade: nagiosxi-deps
--> Processing Conflict: nagiosxi-deps-5.2.9-1.noarch conflicts nrpe
Error: nagiosxi-deps conflicts with nrpe-2.15-7.el6.x86_64
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './1-prereqs'
Re: nagiosxi-deps-5.2.9-1.noarch conflicts nagios-nrpe
Post by dwhitfield »
The first thing I would do is use http://repo.nagios.com/nagiosxi-offline ... _64.tar.gz instead of 5.2.9, unless you're trying to install 5.2.9 for the purposes of a backup.
Also, what's the output of yum repolist?
strmon
Post by strmon »
though, i've switched check to "check_by_ssh" from "chcek_nrpe". Here are the o/p.
"unless you're trying to install 5.2.9 for the purposes of a backup"
yes, i am migrating application from one server to other fresh server.
o/p of yum repo list:-
awesant_6_x86 | 871 B 00:00
base | 3.7 kB 00:00
centos_6_x86 | 871 B 00:00
centos_6_x86_base | 1.0 kB 00:00
centos_6_x86_epel | 1.3 kB 00:00
centos_6_x86_extras | 871 B 00:00
centos_6_x86_spacewalk_client | 1.0 kB 00:00
centos_6_x86_updates | 871 B 00:00
cr | 3.3 kB 00:00
epel | 4.3 kB 00:00
epel/primary_db | 5.9 MB 00:51
extras | 3.4 kB 00:00
puppetlab | 871 B 00:00
updates | 3.4 kB 00:00
repo id repo name status
awesant_6_x86 awesant_6_x86 288
base CentOS-6 - Base 6,696
centos_6_x86 centos_6_x86 0
centos_6_x86_base centos_6_x86_base 13,740
centos_6_x86_epel centos_6_x86_epel 32,404
centos_6_x86_extras centos_6_x86_extras 70
centos_6_x86_spacewalk_client centos_6_x86_spacewalk_client 23
centos_6_x86_updates centos_6_x86_updates 3,674
cr CentOS-6 - CR 0
epel Extra Packages for Enterprise Linux 6 - x86_64 12,215
extras CentOS-6 - Extras 62
puppetlab PuppetLab 565
updates CentOS-6 - Updates 772
repolist: 70,509
strmon wrote:though, i've switched check to "check_by_ssh" from "chcek_nrpe".
Are you still having dependency issues?
strmon
Post by strmon »
No, but i need nrpe to be working..! Suggest the fix, please.
Are you installing from source, or using an offline install?
Our recommendation is installing on a clean, and minimal system - there seems to be quite a few things installed on here, as well as additional repositories. I would start fresh and with a minimal machine if possible.
You could run yum remove nrpe-2.15-7.el6.x86_64 as XI will install NRPE - but, you may still see further issues depending on what packages are already installed.
In addition to what @rkennedy said, what error are you getting now that you are running a different command?
