When i check my configuration no errors are detected..the nagios service is correctly launching and i'm connected on the web interface.
But when i switch tab i have this error :
When i check nagios.log i see this error:
Error: Unable to create temp file '/usr/local/nagios/var/nagios.tmpxxxx' for writing status data : Permission denied
I suspect a permission error..
Thanks a lot
Reason:marking with green check mark
Can you compare your output of ls -la /usr/local/nagios/var/ to mine? I'm running 4.2.2 on Debian, but that shouldn't matter if you're compiling from source using our instructions (well, the instructions are different, but the final product should be similar)
