saving a custom multistacked graph
chrisbooth
Post by chrisbooth »
I've made a Multistacked Graph i'd like to keep and not build every time.
possibly even show it in other areas of nagios.
is that possible?
Re: saving a custom multistacked graph
Yes, you'll want to create a new dashboard from the 'Dashboards' tab, then click the blue arrow in the top left of the graph you've screenshotted. This will allow you to place it on a dashboard page which you can customize.
chrisbooth
great that worked
thank you
No problem - going to lock this thread up!
Feel free to create a new one if you have further questions in the future.
