Imported Service Dependencies Config Name are chagned
nthaler
Post by nthaler »
Hello Nagios!
Quick question is there any way to stop Nagsio-XI from renaming my Service Dependencies config_name?
Example
I go to import a service dependency file containing the below config.
define servicedependency {
config_name ajnr maint
dependent_host_name hwmaint24
dependent_service_description H10 - ajnr - jserv 1
host_name hwmaint24
service_description Maintenance Page - ajnr - hwmaint.anjr.org
inherits_parent 1
execution_failure_criteria w,u,c,
notification_failure_criteria w,u,c,
dependency_period 24x7
After importing it, verifying the config and restarting nagios it shows up with a config_name of Import 1484327380.3643
Is there any way to stop this and keep my original config_name?
This only happens when I import Service Dependencies.
Thank you,
Nicholas
avandemore
Re: Imported Service Dependencies Config Name are chagned
Post by avandemore »
I am not aware of anyway to do this, I can submit a feature request for this if you like?
Previous Nagios employee
nthaler
Post by nthaler »
Yes Please do.
It seems weird that this is the only type of import that changes the config name. It also makes searching for service dependencies more difficult.
avandemore
I have created FR 10695 for this issue. You can inquire here or via ticket for its status.
