This might be something simple I am missing or misinterpreting
I am using the below plugin using nsclient ++ but for some reason I am getting "Unknown command(s): check_citrix_sessions"
https://exchange.nagios.org/directory/P ... ns/details
#Under
[/settings/external scripts/wrappings]
#I have this
check_citrix_sessions = cscript.exe C:\Program Files\NSClient++\scripts\custom\check_number_of_citrix_sessions.wsf all all 500 1000
Is the format of the command completely wrong?
Re: check_citrix_sessions
Nevermind. We got it. I added it to the wrong section.
