I am pleased to say we have gotten most of our configuation working thanks to Nagios support here on the forums. For those just reading this, we are implementing a tiered NLS environment where multiple NLS instances will need to send data between each other. See the link here for details:
https://support.nagios.com/forum/viewto ... 37&t=41560
We now have data flowing from lower tiered NLS nodes to parent nodes. However we now need to secure the communication at the protocol level. In the previous post, we were advised to set the client to use the following:
elasticsearch {
cluster => 'cluster_id'
host => 'host_ip'
document_type => '%{type}'
protocol => 'http'
ssl => true
workers => 4
That does not work because the server does not have a server certificate. From a NLS perspective, we have looked at the documentation here which instructs us on how to setup a SSL cert for the web page and NLS use:
https://library.nagios.com/library/prod ... igure-ssl/
I am assuming we need to configure ES to use the certificate specifically so any advise would be greatly appreciated. So can anyone advise on how to setup and use a cert / SSL with ES?
Also, as a side note, we have been approved to purchase NLS. However my director is asking how long the next version will be out because he says we really need to have user/group access which appears on the roadmap for the next version. He says he would rather wait a month or so to purchase and deploy then rather than purchase the solution, deploy, and then have to upgrade or re-deploy due to the potential for downtime. So the question here is since the new version of the elk stack will be used is in the next version will there be a direct upgrade path between current product line?
ES SSL Server Config
Re: ES SSL Server Config
I believe you would need to configure a certificate to listen on 9200, as well as well as open it up to other hosts.
See this section from the elasticsearch output page -
Specifically, two other fields you'll want to use for your output -
See these links for reference -
https://www.elastic.co/guide/en/logstas ... earch.html
It might make more sense to setup an individual HTTP output / input for this depending on your use case -
https://www.elastic.co/guide/en/logstas ... -http.html
The new version of NLS is due out in the near future, which will include upgrades to the main components. (elasticsearch / logstash / kibana)
hosts
Value type is array
Default value is ["127.0.0.1"]
Sets the host(s) of the remote instance. If given an array it will load balance requests across the hosts specified in the hosts parameter. Remember the http protocol uses the http address (eg. 9200, not 9300). "127.0.0.1" ["127.0.0.1:9200","127.0.0.2:9200"] ["https://127.0.0.1:9200"] ["https://127.0.0.1:9200/mypath"] (If using a proxy on a subpath) It is important to exclude dedicated master nodes from the hosts list to prevent LS from sending bulk requests to the master nodes. So this parameter should only reference either data or client nodes in Elasticsearch.
ssl
ssl_certificate_verification
